Load filament double tap issue
I have this constant issue with the Load Filament button: When I press it, it registers as 2 presses, and starts heating up to load PLA.
If I am printing anything else, it takes a bunch of tries to get the filament selection menu.
The weird thing is, none of the other menu items do this: They only register 1 press!
Has anyone else seen this? Any suggestions?
RE: Load filament double tap issue
I think the selector button might be out of order and bounce a bit. Maybe the control knob is stuck somewhere or is too loose.
Anyway, if the problem persists, I would turn to the prusachat. If it's on the board, I am sure it will be replaced.
good luck!
I have exactly the same. Is this resolved somehow?
@wwwhatever
No, I often have the double-tap issue, No sure why.
