Load filament double tap issue
dclaar
(@dclaar)
I have this constant issue with the Load Filament button: When I press it, it registers as 2 presses, and starts heating up to load PLA.
If I am printing anything else, it takes a bunch of tries to get the filament selection menu.
The weird thing is, none of the other menu items do this: They only register 1 press!
Has anyone else seen this? Any suggestions?
Postato : 01/10/2020 4:35 am
RE: Load filament double tap issue
Posted by: @doug-c5
I think the selector button might be out of order and bounce a bit. Maybe the control knob is stuck somewhere or is too loose.
Anyway, if the problem persists, I would turn to the prusachat. If it's on the board, I am sure it will be replaced.
good luck!
Postato : 01/10/2020 8:36 am
wwwhatever
(@wwwhatever)
I have exactly the same. Is this resolved somehow?
Postato : 23/11/2020 9:10 pm
Utenti
@wwwhatever
No, I often have the double-tap issue,  No sure why.
Postato : 23/11/2020 10:29 pm
