LCD Knob not working after Firmware update
I just flashed my MK3/MMU2s today with the latest firmware.
After a successful update to 3.11.0.4955, the encoder knob quit responding. No beep.. nothing.
I checked both cables (including continuity checks) and they were fine. Solid connections too.
I reinstalled the prior firmware that was known to work (3.10.0.4481)
At this point, the knob still isn't working, but I get a beep when I press it.
Any ideas?
Napsal : 16/05/2022 6:20 pm
Topic starter
answered:
RE: LCD Knob not working after Firmware update
So, long story short.... I ended flashing the printer with 3.9.0, which worked. Then found out that the mmu and filament sensor cables were swapped.
After the cables were fixed, I reflashed 3.11, and everything was back to working
Napsal : 17/05/2022 5:44 pm
Good to hear you found the issue.
Napsal : 18/05/2022 4:02 am
