Z Adjust - Newbie
Construtor
(@construtor)
Z Adjust - Newbie
Hello there, I am new to Prusa environment but very familiar with 3D printing...  I am helping out a friend, but I am stuck. This is the MK3S kit. Everything works as it should but, not quite.  I have done the Z calibration for each bed sheet (smooth and textured), but when I go to print (using simplify 3d, because that's what he uses), it seems that the Z adjust didn't take. While the print starts, I can go to Live Z adjust, and have to input the same value of, in this case, -1.200mm, on top of the the already showing -1.200mm?  I must be doing something wrong, no?  Any help would be greatly appreciated!!! THANK YOU in advance.
Respondido : 29/08/2022 6:37 pm
Construtor
(@construtor)
RE: Z Adjust - Newbie
I have just tried with SuperSlicer and, as expected, it yield the same result...Z super far away from the bed!?
Respondido : 29/08/2022 7:00 pm
Construtor
(@construtor)
The firmware loaded is the 3.11.0-04955
Can't edit old threads?
Respondido : 29/08/2022 7:13 pm
you only get a short edit window.
wait a little longer and the opportunity evaporates!
Joan
Respondido : 29/08/2022 8:43 pm
1 les gusta
RandyM9
(@randym9)
Are you running the live adjust z routine built into the printer’s LCD menus?
https://help.prusa3d.com/article/live-adjust-z_112427
Once completed the value should not change.
For fine tuning you can move from the built-in calibration routine to Jeff Jordan’s excellent ’Life Adjust Z - my way’ process.
Have you tried printing any of the pre-sliced (gcode file) objects included on the SD card that shipped with the printer? What was the result?
Respondido : 30/08/2022 4:25 am
Construtor
(@construtor)
Thank you for the reply.  I was on live chat with Prusa for over 1 hour trying to figure this out... I am building this printer for a friend and he wants to continue using Simplify 3D... So after stumping with tech support, I was wondering if my Starting gcode was somehow causing this issue, even though nothing looked suspicious. Well, bingo.  I printed something from the SD card, already sliced and it worked! I then sliced something with PrusaSlicer (I use SuperSlicer for my Vorons) and that worked. Last step was copy the gcode from PS to S3D...and with a few tweaks, it is all working as it should!!!
Thank you again for taking the time!!
Respondido : 31/08/2022 5:51 pm
RandyM9
(@randym9)
Great! Glad you got it sorted.
Cheers
Respondido : 31/08/2022 6:38 pm
