Uneven first layer
Hi all,
I've never managed to perfectly assemble my prusa MK3s+ and I'm not entirely sure why it is. I reduced the belt tension, upgraded the firmware and did a test print after the first layer ht calibration. I end up with uneven first layer as I show in the pic. On large prints this causes delamination problem and warping. Any idea how to fix this ?
Este debate ha sido modificado el hace 4 years 2 veces por DrGanti2000
Respondido : 01/07/2021 6:09 pm
RE: Uneven first layer
What is the result from your XYZ calibration?
Respondido : 01/07/2021 11:50 pm
Topic starter
answered:
I ran the bed levelling mesh visualizer and i think it tells us what the problem is, there seems to be a significant Z variation over the area of the bed. There is a proposed solution using Nyloc nuts shown here, that is worth a try I suppose, I will do this when time permits, and update results here.
Esta publicación ha sido modificada el hace 4 years por DrGanti2000
Respondido : 02/07/2021 12:02 am
