Uneven first layer
DrGanti2000
(@drganti2000)
Uneven first layer
Hi all,
I've never managed to perfectly assemble my prusa MK3s+ and I'm not entirely sure why it is. I reduced the belt tension, upgraded the firmware and did a test print after the first layer ht calibration. I end up with uneven first layer as I show in the pic. On large prints this causes delamination problem and warping. Any idea how to fix this ?
  1.  20210701_200039.jpgTop view of uneven first layer
Questa discussione è stata modificata 5 years fa 2 tempo da DrGanti2000
Postato : 01/07/2021 6:09 pm
RE: Uneven first layer
What is the result from your XYZ calibration?
Postato : 01/07/2021 11:50 pm
DrGanti2000
(@drganti2000)
@diem
Xyz cal results SkewXy point distance
Postato : 01/07/2021 11:57 pm
DrGanti2000
(@drganti2000)
I ran the bed levelling mesh visualizer and i think it tells us what the problem is, there seems to be a significant Z variation over the area of the bed. There is a proposed solution using Nyloc nuts shown here, that is worth a try I suppose, I will do this when time permits, and update results here.
Questo post è stato modificato 5 years fa da DrGanti2000
Postato : 02/07/2021 12:02 am
