Trouble with first layer PTEG
ECUAdam
(@ecuadam)
I'm currently trying to print the lack enclosure parts and am not having any luck. PLA seems to print just fine, but when I go to PTEG (Overture) I'm having trouble getting the first layer to stick. I have trouble with the first layer on these prints and other ones that I've designed. I just downloaded the gcode from prusa for the files I need to print for the enclosure and put them on an sd card and hit print. If I can baby sit the print and clean the nozzle for the first 2-3 layers the piece will print fine. The main problem I believe I am having is plastic is collecting on the nozzle as it prints and then makes a mess somewhere in my print eventually.
I originally thought my z axis was too low causing too much squish, but if I raise it any more it will not stick to the bed while printing.
I've tried bed temps from 80-90 and nozzle temps from 230-240. After 4 failed attempts this morning while tweaking settings, I'm at a loss... Thanks for your time
Postato : 05/12/2020 6:09 pm
RE: Trouble with first layer PTEG
Posted by: @ecuadam
Hello and welcome to the Prusaforum!
First of all it is important that the printing bed has been cleaned with dishsoap and warm water and then dried with a lint-free cloth.
To set up the first layer this thread will help you: https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-assembly-and-first-prints-troubleshooting/life-adjust-z-my-way/
Postato : 05/12/2020 11:06 pm
ECUAdam
(@ecuadam)
This is exactly what the problem was. This method of z calibration is much better than the one the printer comes with. I got it dialed in with just two test prints. Thank you so much for the help.
Postato : 06/12/2020 5:16 pm
@ecuadam
I am glad that the tips helped you!
happy printing!
Postato : 06/12/2020 11:48 pm
