Step 14 Extruder assembly - serious problem with M3x40
max
 max
(@max-2)
Dear all,
everything went well and smoothly up to step 14. Unfortunately the step 14 it contains an error:
* Insert two M3x40 screws, you've prepared earlier. Tighten them, but be careful, they are slightly longer (2-3 mm), than the thickness of the entire assembly
And this is the expected result, with 2.3 mm exceeding screws:
Unfortunately m3x40 screws are too long for this part, as screws exceed by 14 mm over the bottom place:
Below the part, there is a m3x14 screw as example:
which matches exactly the exceeding length.
With this, I cannot assemble the X-carriage as shown in the step 19.
How can fix this?
Thank you for your help.
Max
Postato : 04/11/2020 3:20 pm
Baklin
(@baklin)
RE: Step 14 Extruder assembly - serious problem with M3x40
Did you install the extruder cover in step 14? That would explain the screws sticking out that much.
Postato : 04/11/2020 9:32 pm
max
 max
(@max-2)
Yes, sure!
And as you can see from the picture, both supposed "M3x40" screws remain raised only by a few millimetres (2-3 at most, see orange arrows) with respect to the hot hand assembly component , when placed to the box.
I guess that this is not possible, unless a big misunderstanding.
The hothand assembly height is about 28 mm:
while the total length if a M3x40 screw is more than 40 mm:
That's why the screws protrude by 14 mm, much more than the expected 2 mm.
Unfortunately there are no M3x25 screws in the box, which probably fit better.
I am stuck here.
Max
Postato : 05/11/2020 10:40 am
max
 max
(@max-2)
Ah!!!! That's clear now: there is an important MISSING step in the Part 14 of this tutorial.
THE DESCRIPTION OF WHEN AND HOWTO PLACE THE Extruder-cover  IS MISSING COMPLETELY.
This tutorial chapter must be fixed as soon as possible, specially for new users.
Now is perfect:
Postato : 05/11/2020 12:53 pm
Baklin
(@baklin)
These steps are in the manual.
I checked my printed manual and the online manual and both have this step in it.
In step 11 you prepared the cover and in step 14 it is marked with a purple dot.
Place the Extruder-cover on the Extruder-body. Again, make sure that all three parts are properly aligned.
And on the 3rd picture it is marked with a purple arrow (not very clear in the printed manual)
Read all instructions carefully and happy printing when you have it fully assembled.
Postato : 05/11/2020 6:55 pm
max
 max
(@max-2)
Thank you for point this out.
Postato : 06/11/2020 7:51 am
