Problem with self test: heater/thermistor not connected?
tshonka
(@tshonka)
Hello,
I got a problem with the selftest. Already checked the connections 3 times and did the test 4 times.
Does anyone know how to solve this?
Napsal : 23/09/2019 8:05 am
Bunny Science
(@bunny-science)
RE: Problem with self test: heater/thermistor not connected?
Yikes. From your pict there are multiple problems.
Of course the critical filament sensor jack is obscured by the ribbon connectors in your pict, but I don't see your extruder thermistor plugged in. It is the one with yellow/green shrink wrap.
Check your filament sensor plug. It looks reversed left/right. From left to right I should see white, black, red. In your pict, white appears to be on right.
I also think your power panic is plugged into the heater thermistor jack.
Connections should be as below
Napsal : 23/09/2019 8:34 am
tshonka
(@tshonka)
thanks, it solved the issue 🙂
Napsal : 26/09/2019 11:05 am
Yu Tang
(@yu-tang)
I had the same error during self test (tried 4 times now).
see pictures. please help! Many thanks!
Napsal : 31/01/2021 5:53 pm
