Printer do not turn on any more
thomas-4
(@thomas-4)
Good morning all,
I have printed yersterday and everything was ok so far. I had in the passt some issues with first layer but the last prints went good.
Some minutes a go I like to print my new created object from yesterday and now the printer do not turn on any more.
That means:
- No display (do not turn on)
- No light at back switch (do not turn on)
- Not reachable via octoprint (seems to be complete dead)
- I check if power is comming from the wall, and yes there is no problem at all
What I can do next ? I buy the full assambled printer cause I don't like to do some hardware stuff. I just like to USE it.
BR,
Thomas
Respondido : 08/12/2019 8:30 am
Razaro
(@razaro)
RE: Printer do not turn on any more
Connect it via usb to PC and see if it is discovered. If not maybe check fuses in the box, it opens with one screw.
Respondido : 08/12/2019 11:31 am
thomas-4
(@thomas-4)
@b3-marek thanks for help! I try to connect printer to PC direct with no luck. I also check all three fusen, all of them looks good for me, non of them is blown.
What could I do next ?
BR,
Thomas
Respondido : 08/12/2019 6:40 pm
Razaro
(@razaro)
https://manual.prusa3d.com/Guide/8.+Electronics+assembly/1052?lang=en
Check step 37 if nothing disconnected or came loose. Check LCD ribbon cables etc
Respondido : 08/12/2019 6:44 pm
rmm200
(@rmm200)
My problem was the power cord was not fully inserted into the PSU. That is a tight fit...
Respondido : 08/12/2019 6:53 pm
Razaro
(@razaro)
Check also if the cables going into PSU are also connected.
Respondido : 08/12/2019 7:02 pm
thomas-4
(@thomas-4)
I did that, nothing is loose everything is fitting good, same for the power cable. I have the fear that PSU dided 🙁
As I said, not light showing if turn on the swtich. I think this should always work right? Hm 😐
Respondido : 08/12/2019 10:02 pm
rmm200
(@rmm200)
If it were me - I would disconnect the + and - leads that go to the heated bed. See if the Einsy powers up. Looking for a short that may have crowbarred the supply.
I think you are the point of contacting Support. Click EShop above, log in, and you should have a Chat button.
They can step you through it better than we can.
Esta publicación ha sido modificada el hace 6 years por rmm200
Respondido : 09/12/2019 6:16 am
