PLA Print: Not Adhering to Surface
avernian
(@avernian)
After successfully completing the setup tests, I went to perform a test print of a simple part using PLA filament.
I selected the surface temperature for PLA from the menu options, and it began to print. Unfortunately, there was no adhesion, as seen below:
What could be causing this, and how could I go about resolving it?
On a secondary note, what is the function of the single nylon filament during setup?
Napsal : 17/12/2020 7:02 am
RE: PLA Print: Not Adhering to Surface
for the lack of Adhesion, reset your Live Z. setting...
I found the prusa first layer Calibration tool is poor, so I use this
The Nylon Filament in the extruder cable bundle, is there to give Strain Relief to the cables, reducing the sharp flexing, immediately behind the X carriage cable fixing point
Napsal : 17/12/2020 12:09 pm
avernian se líbí
Timo
 Timo
(@timo-4)
Seems that your Pinda is not fastend propperly and you miss a srew.
When Pinda is moving you can't find the right Z hight.
Napsal : 18/12/2020 1:48 pm
