[Solved] New kit MK3S+ first layer problem
livius
(@livius-2)
Hi
new kit MK3S+
where is the problem with the first layer, as surface looks ok? but left and right side is not good?
Posted : 10/02/2022 11:21 pm
RE: New kit MK3S+ first layer problem
are you using 7x7 mesh bed levelling?
I find the Prusa first layer calibration, hard to use, so I use this process
these values are unique to my printer, your values will be different, look at both top and bottom...
Regards Joan
Posted : 10/02/2022 11:34 pm
livius
(@livius-2)
I have changed to 7x7 and i print the square but result is strange even if life-z will be wrong
Can someone point me what can be wrong?
I mark also left "margin" with red questionmarks.
There is also some vertical artifacts too.
Posted : 11/02/2022 8:59 am
livius
(@livius-2)
The problem was not calibration of Life Z but srew in X and Y motors xD.
Like in this post.
https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-assembly-and-first-prints-troubleshooting/help-strange-issue-poor-x-axis-on-left-hand-side-only/#post-578734
Posted : 11/02/2022 11:24 am
Bob
 Bob
(@bob-2)
In your very first image the first layer looks good, but the lifting edges are a sign of a dirty bed.  You can even see particles on the bed above the rectangle.  Clean that sheet well.
Cheers
-Bob
Posted : 11/02/2022 3:38 pm
