How to fix nozzle head
Nicolo
(@nicolo-2)
I've been struggling to get an even first print and I noticed that my nozzle head kept getting dirty and was uneven is there a way for me to fix it or do I need to try and get another one?
Opublikowany : 14/08/2020 6:29 am
RH_Dreambox
(@rh_dreambox)
RE: How to fix nozzle head
If the filament curls up and gets stuck on the nozzle, it is due to a too high Z level. Try lowering the nozzle a little so that your first layer is homogeneous and fine.
If this does not help, it may be because the bed is dirty (fat fingerprints). Then wash the plate with detergent and water.
Opublikowany : 14/08/2020 2:50 pm
Nicolo
(@nicolo-2)
I've tried both of these multiple times and I still fail to get an even print.
Opublikowany : 14/08/2020 8:06 pm
RH_Dreambox
(@rh_dreambox)
The correct Z-level is when the filament string is 0.2 mm thick, it is the same thickness as two office papers.
This popular post describes how to do.
Opublikowany : 15/08/2020 6:59 am
Jerry
(@jerry)
Posted by: @lomas-n
I am not sure what you mean by uneven. Can you explain?
Opublikowany : 16/08/2020 4:33 am
Nicolo
(@nicolo-2)
@jerry-s3
I think I have it almost figured out my Y-axis belt was slipping so I kept getting really poor prints I leveling my bed rn to smooth out the rest.
Opublikowany : 16/08/2020 4:35 am
