Deteriorating nozzle temperature correctness leading to Err: MINTEMP error
Cronostitan
(@cronostitan)
I got my Prusa Kit 14 days ago, assembled it without problems and was able to print just fine for several days.However recently I get  the dreaded
Err: MINTEMP
error when I switch on the printer.
My room temperature is at ~ 22 °C, bed temperature is correctly shown at 22 °C. However, my nozzle temperature shows 14 °C which is under the minimum of 16 °C - so I get this error.
If I touch the nozzle for a while with my finger I can raise the temperature to 16 °C, so I can at least start the print. The 'calibration' of the temperature seems to be deteriorating over the last few day.
Anyway, I am pretty sure that is not how it is supposed to be. What can I do to get a correct nozzle temperature? Is this a hardware fault?
Yes, I ran the temperature calibration already.
Please help me  - best regards
Carsten
Dieses Thema wurde geändert Vor 7 years 2 mal von Cronostitan
Veröffentlicht : 15/05/2019 5:10 pm
Vojtěch
(@vojtech)
RE: Deteriorating nozzle temperature correctness leading to Err: MINTEMP error
That sounds like a bad thermistor.
Veröffentlicht : 15/05/2019 8:03 pm
Tom Ford
(@tom-ford)
Did you find out how to fix this issue? My mk3 does the same thing: nozzle temperature is showing approximately 8C below room temperature and I have to warm it up with my finder when starting from cold to get around MINTEMP error.
I'm wondering if the this is affecting the temperature during printing also - my PLA prints have more stringing than I think is normal.
Veröffentlicht : 27/07/2019 4:47 pm
You want to find the root cause, but assuming it doesn't throw the MINTEMP error until you issue a nozzle warmup command, a temporary work-around might be to move the nozzle above the heated bed on startup.
Veröffentlicht : 27/07/2019 5:01 pm
