3DHubs Marvin keeps failing
DustyTools
(@dustytools)
Hi All,
I have a new printer up and running, it passed all the tests etc. The Batman print works really well with PLA but 3DHubs Marvin keeps coming loose about 80% of the way into the print. I have tried it four times and each times it failed almost at the same point.
My friend with a different printer recommended hair spray, and that worked, but he also felt that the Prusa shouldn't have this issue, especially with one of the test prints.
I have tried cleaning the smooth PEI sheet with both alcohol and acetone and neither helped.
Any guidance would be appreciated.
Thanks
Opublikowany : 04/11/2018 5:15 am
Re: 3DHubs Marvin keeps failing
This is pretty common, and there are 2 main causes:
  • Your bed needs cleaning. For a quick test, dunk it under the kitchen sink and wash it with some dish soap. Dry it off with a clean paper towel and avoid touching it at all costs.
  • Your Live-Z adjustment might be off. Try the "life adjust" procedure for a much simpler and easier-to-understand method.
  • My notes and disclaimers on 3D printing
    Opublikowany : 04/11/2018 5:23 am
    toaf
     toaf
    (@toaf)
    make sure all the screws are tight. and belts. if memory serves that's about the time its doing allot of retraction right?
    Opublikowany : 04/11/2018 6:13 am
