3DHubs Marvin keeps failing
Hi All,
I have a new printer up and running, it passed all the tests etc. The Batman print works really well with PLA but 3DHubs Marvin keeps coming loose about 80% of the way into the print. I have tried it four times and each times it failed almost at the same point.
My friend with a different printer recommended hair spray, and that worked, but he also felt that the Prusa shouldn't have this issue, especially with one of the test prints.
I have tried cleaning the smooth PEI sheet with both alcohol and acetone and neither helped.
Any guidance would be appreciated.
Thanks
Re: 3DHubs Marvin keeps failing
This is pretty common, and there are 2 main causes:
make sure all the screws are tight. and belts. if memory serves that's about the time its doing allot of retraction right?
