Nozzle clogs during print
olve.v
(@olve-v)
I have had a problem for a while were the printer cloggs after 10 minutes with the prusa pla. I have tried drypulls and nothing works. The drypull does reveal a odd shape and the printer makes sort of a tickibg noise. I have checked the tube inside the hotend and it is not deformed or anything and now i do not know what to do. https://goo.gl/photos/pBRKMjP9p7RJFVDX9 at the link are photos and a vide. It is ment to describe the sound and that the print startet acting up with lots of lumps.
Opublikowany : 23/04/2017 5:59 pm
AJS
 AJS
(@ajs)
Re: Nozzle clogs during print
Very difficult to diagnose with your description, but two things to check:
1) Tension on the idler screws that hold the filament against the stepper gear. If too tight, they cut into the filament and start to slip. Too loose, and they don't grab. The clicking sound is what happens if it is too tight. Might want to loosen those screws a bit.
2) What temperature are you running at?
3) If it is a clog - e.g. if your filament is very dusty - you might want to consider a filament filter. (Basically run the filament through a foam sponge before it goes into the printer. That keeps the dust from accumulating in the print head.
Good luck.
Opublikowany : 23/04/2017 6:31 pm
olve.v
(@olve-v)
I will cange the crews that tension. I run at 210 for pla during print and i do not think the filament is that dusty when it is a week old
Opublikowany : 23/04/2017 7:02 pm
JeffJordan
(@jeffjordan)
Member Moderator
is your coldend fan running properly ?
without it your filament would melt inside the heatbreak, which will cause the described effects.
Opublikowany : 23/04/2017 7:25 pm
olve.v
(@olve-v)
Yes, the fan is working fine
Opublikowany : 23/04/2017 7:36 pm
PJR
 PJR
(@pjr)
Antient Member Moderator
What retraction settings are you using?
Peter
Opublikowany : 23/04/2017 10:23 pm
olve.v
(@olve-v)
Hi, i havent tamperd with retraction settings. This happends on the gcode that prusa provides aswell
Opublikowany : 23/04/2017 11:43 pm
