Dots in prints on thin layers
stephen.e3
(@stephen-e3)
Does anyone have any idea what can be causing this?
On layers which are stepping up on Z axis, you get these repeating dots are regular spaced intervals along the X axis. You only see them on the top most layer, and you don't see them if it is a large flat surface, only if it is a stepping layer.
I'm guessing it somehow relates to the extruder gear, but what could cause an issue like that?
I have tried increasing the Extrusion Multiplier to 1.02 and it makes no difference, so I do not believe it is under extrusion.
This is printing PLA.
Veröffentlicht : 12/02/2017 12:56 pm
JeffJordan
(@jeffjordan)
Mitglied Moderator
Re: Dots in prints on thin layers
➡ seems like rubber particles from your x-axis belt: check that the belt doesn't scrape somewhere.
Veröffentlicht : 12/02/2017 5:36 pm
david.b14
(@david-b14)
My guess is it is a slicer / object design issue.
- Hold that print up to the light, those are hollow spots, correct? If so then:
- - Does it happen with the batman print?
- - Try increasing the slicer top layer setting from 5 to 8.
Veröffentlicht : 12/02/2017 5:39 pm
JeffJordan
(@jeffjordan)
Mitglied Moderator
🙄 i think you're right david. seems that these are little holes, not particles...
➡ so it's a settings problem with the slicer. first thing i would try is to increase the number of top layers by 2 and maybe the infill (if the layers underneath are to hollow).
Veröffentlicht : 12/02/2017 6:10 pm
stephen.e3
(@stephen-e3)
Thanks for the suggestions. They are definitely little holes.
They don't occur on top surfaces though, they only occur on areas where you are stepping up the X axis like that.
I'll have a play around with other slicer settings and see if it makes a differences. These are designs I am creating and then exporting direct from Fusion 360. I am importing them into S3D and printing using the latest Prusa i3 MK2 profile from the Configuration wizard.
Veröffentlicht : 12/02/2017 6:55 pm
david.b14
(@david-b14)
That surface does not look flat.... slicers will have challenges on the top layers that are curves... like the tree frog print.
The Beta PE Slic3r has a new feature to handle this ( variable layer heights).
Veröffentlicht : 12/02/2017 8:08 pm
