Problems printing with Hatchbox PETG filament.
Marius C.
(@marius-c)
Hi guys,
Wondering if you have any idea why I am getting loads of small bubbles when printing and why the filament looks puffy / foamy when coming out from extruder.
I have no problems when printing abs and pla .
I am using Hatchbox white PETG and I tried printing with noozle 240 - 255 and bed 90 , but I am getting the same results.
Thanks
Posted : 12/02/2017 1:21 pm
JeffJordan
(@jeffjordan)
Member Moderator
Re: Problems printing with Hatchbox PETG filament.
the effect that you describe means: the filament has soaked up humidity from the air -> it's hygroscopic.
by the way: you should have heard some crackeling noise from the hotend when printing your bubbles...
💡 unfortunately petg filament differs from brand to brand.
now the opinions about petg and being hygroscopic differs at the http://www ... which might have to do with the fact that some brands are very hygroscopic, others aren't.
➡ so treat it like nylon filament: put it in the oven at about 60°C for at least two hours. then the humidity inside the filament should have disappeared and you should be able to print with it as good as with pla.
🙄 personally i like to print with transparent petg filament (from herz here in germany) at 255°C hotend and 90° bed temperature. 😛
Posted : 12/02/2017 5:19 pm
Wirlybird
(@wirlybird)
It does look like typical moisture.
Also watch out for counterfeit Hatchbox filament. It is all over Amazon and eBay. Hatchbox only has 4 (at last check) authorized sellers.
Posted : 14/02/2017 4:19 pm
avi.s
(@avi-s)
When printing with the Hatchbox PETG I set the hotend to 240 and the bed to 75 and it works very well. However I do keep the spools in a sealed box with desiccant which keeps the humidity level at 20%-23%.
Posted : 15/02/2017 7:03 am
