Print nozzle hitting bed with PINDA all the way down.
Page 2 / 2
david.m17
(@david-m17)
Re: Print nozzle hitting bed with PINDA all the way down.
Suggestions on how to proceed?
Posted : 03/02/2017 3:36 am
ryan.c4
(@ryan-c4)
If nothing is touching the endstop before the carriage hits it then you may need to move your frame a bit. Did you attach the power supply bracket onto the rods in the right direction? The spacing appears to be off by enough for that to potentially be the problem.
Posted : 03/02/2017 4:33 am
Ancientwolf
(@ancientwolf)
Didnt anybody notice he said at the start that his PINDA is all the way DOWN?
Raise it to about 1-1.5mm ABOVE the level of the tip of the nozzle. No wonder the nozzle is slamming into the bed.
Details guys.
Nozzle ----> V U <---- PINDA needs to sit 1-1.5mm HIGHER than the Tip.
Yeah, its that guy... 3D Nexus
Posted : 03/02/2017 5:55 am
ryan.c4
(@ryan-c4)
Yes, but on the video the Y axis doesnt go far enough back before being tripped.
Posted : 03/02/2017 2:45 pm
david.m17
(@david-m17)
The end of the story --
As it turns out, the PINDA was fine. The y-axis needed to move about -7mm in order for the calibration points to be where the software was expecting them to be. This put the z-axis about 107mm from the y corners. Now calibration works fine. Thanks for all the tips. Learned a lot about this stuff!
Posted : 04/02/2017 10:09 pm
brandon.p
(@brandon-p)
I have had the same problem forever! Thank you for your video and all your explanations. How did you determine that the Y needed to come down -7? Was it just a trial and error until you got it right?
Did you go to Calibration > bed leveling correction to toggle your Y-axis?
Posted : 26/10/2018 10:25 pm
Page 2 / 2
