Hot end fan self test issue
RevivalEngineeringNZ
(@revivalengineeringnz)
Mitglied
Hi all, new to prusa printers and community.
I have a mk2.5s that keeps failing self test at the hotend fan test.
Ive checked the wiring and tried another fan.
Its wired up with a two wire fan direct to the board as per the wiring diagram.
Ive done a reset and flashed the firmware.
I can get the printer to calibrate and do the first layer and print, the fan runs. I get the message saying the printer has not been calibrated.
I have to skip past it and turn off the fan test to get the printer running.
What am i missing?
The printer was previously fine until i tried to run the calibration wizard. Any help much appreciated.
Thanks, Tim.
Veröffentlicht : 01/07/2023 9:09 am
Jirka
(@jirka-4)
Mitglied
RE: Hot end fan self test issue
I have exactly the same problem. Only with hot end termistor. Chek all. Plug in rambo have 5v termistor react on change. Flush firmvare. Still self test error.
Veröffentlicht : 18/11/2023 5:51 am
