dimensions of the XL
Pagina 4 / 5
Johan
(@johan)
RE: dimensions of the XL
I like to know the dimension marked in yellow to be able to build a table:
Postato : 30/01/2023 6:50 pm
Niklas
(@niklas-2)
If i think correctly it was  60 cm ~
Edit:
yap 66cm
Postato : 30/01/2023 7:08 pm
Johan
(@johan)
Thanks but that is not the dimension I'm looking for. I like to know the dimension of the bottom part, i.e. between the feet without the display and power supply sticking out.
Postato : 31/01/2023 6:54 pm
Niklas
(@niklas-2)
no one can answer this atm  -  i think its  60 cm... at least  - might be 62 cm..
Postato : 31/01/2023 6:56 pm
Johan
(@johan)
Hopefully someone from the Prusa team that can reply? It's quite simple dimension to add to the drawing.
Postato : 01/02/2023 6:42 pm
Utenti
I doubt you will get a response.  I have seen very few questions answered by the Prusa Team on this forum.
Postato : 01/02/2023 6:59 pm
ntdesign
(@ntdesign)
Posted by: @vegas-pay-llc
The print would take so long that something bad is certain to ruin the print before completion. It is easier for me to make smaller printers and more moving hotends. Elimination of purge blocks makes the tool changer a far superior approach when compared to what I have been designing with MMU filament selectors.
What an interesting problem. Could you put multiple hotends on a bar (i.e. no independent motion), build a printer with a really long x axis and swap the whole bar manually for another one preheated and loaded with another color ? That way you lose only one specimen if a hotend clogs, and you can send the same gcode to everything at once. Are you using airbrush nozzles?
Postato : 08/02/2023 2:51 pm
Jesper Hildebrandt Andersen
(@jesper-hildebrandt-andersen)
Any updates on the dimensions ?
Looking in to making a storage unit for two of this.
Postato : 21/02/2023 9:09 pm
Artur5
(@artur5)
Posted by: @johan
Measuring on my monitor the lengths of that part and the upper depth (77.5 cm ), the dimension you want to know is 53.5 cm. That is, if the drawing supplied by Prusa is made to an exact scale. Also, consider what is written at the bottom right of the picture: " work in progress, dimensions may change in the future ".
So, no positive answer at the moment but, unless they make significant changes on the final design of the frame,  I'd be surprised if the final figure isn't within 2-3 cmt of 53.5.
Postato : 22/02/2023 9:31 am
Johan hanno apprezzato
Robert
(@robert)
Does anyone have info about the weight of xl printer with 2 heads and 5 heads ?
Thank you.
Postato : 15/03/2023 11:08 am
Utenti
No one will be able to answer this on the forum because no one has one.  Contact the shop via Chat and maybe they can help you.
Posted by: @robert
Thank you.
Postato : 15/03/2023 12:47 pm
Pintie
(@pintie)
well i can...
it is in the XL manual
Weight (with packaging / without packaging): 35.0 kg max. / 25.3 kg max. (without filament)
Postato : 15/03/2023 1:27 pm
René
(@rene-3)
Posted by: @robert
Thank you.
The number of heads does not affect the width of the printer frame.
Utenti
Posted by: @rene-3
Posted by: @robert
Thank you.
The size of the filament spools can if you use the filament holders:
With out them:  800×800×900* mm (31.49’’ ×31.49’’× 35.43’’)
Postato : 19/03/2023 1:56 am
Selta
(@selta)
Posted by: @rene-3
Posted by: @robert
Thank you.
Posted by: @cwbullet
Posted by: @rene-3
Posted by: @robert
Thank you.
I think you both missed that WEIGHT was what was being asked about.
Postato : 19/03/2023 2:19 am
René
(@rene-3)
That is correct, but even then the number of heads does not affect the width of the frame.
Postato : 19/03/2023 7:09 am
René
(@rene-3)
@Selta
English is not my native language, so it's about weight while I thought it was about width.
Sorry my mistake.
And learned something again.
Postato : 20/03/2023 7:51 am
ssmith hanno apprezzato
Utenti
It is above also:
25.3 kg max.
Posted by: @selta
Posted by: @rene-3
Posted by: @robert
Thank you.
Posted by: @rene-3
Posted by: @robert
Thank you.
Postato : 20/03/2023 11:06 am
Robert
(@robert)
Thank you,
I have contacted prusa shop and the weight is slightly more than 30kg including power supply and 5 heads. The more accurate information they'll send to my email later.
Postato : 20/03/2023 12:40 pm
Selta hanno apprezzato
Surfalex2000
(@surfalex2000)
I´ve designed the XL in Fusion. So no you can really can get a feel for it!
https://www.printables.com/model/423459-prusa-xl-original-size
Postato : 22/03/2023 7:34 am
Pagina 4 / 5
