Stringing - Filament is good
J.P. Ryll
(@j-p-ryll)
Hej,
I really want to fix the stringing-problem with my MINI and it should be possible.
If I try the retraction-test from this site: Teaching Tech 3D Printer Calibration (teachingtechyt.github.io) my Mini could print without stringing. (So my freshly opend filament (Filamentum-PLA)  is'nt causing the failure.
If I print an stringing test, sliced by my own Prusaslicer the resulte is worse. (I tryed nearly 20 prints in the last 2 days)
Allways the same filament. Recently I cleaned the heatbreak and renewed the PTFE-Tube in my upgraded Heatbreak. As nozzel I use an BrozzleX-steel-nozzle 0,4mm.
print from prusaslicer Result: bad
So the thing is, the printer could print without stringing if he is pleased. I compared both gcodes but I could'nt name the difference. hopefully someone out there could help me and find/name the difference.
May there is a problem with the acceleration settings or Jerk????
you could find all my files as attached files.
Thank you very much.
J.P.
Greetings from Germany!J.P.
Veröffentlicht : 29/11/2023 9:15 am
