Layer shifts at precise moment (ASA) - See pictures
Tux
 Tux
(@tux-3)
Hi all,
I'm trying to print some functional parts but at 2 moments, there is some layer shifting visible. The moment the full grounds layers are ready and the wall is printed upwards, the perimeters seem to widen a bit. The 2nd moment there is an issue, is when the wall is printed around the hole for the screw. As you can see in the picture, the defect is not in the entire layer, only near the base plate and the hole. Belt issue?
Any idea how I could fix this? Printing on a Prusa Mini, Bondtech extruder, Prusament ASA, 260° nozzle and 100° bed temp, non-heated enclosure with ambient temp of 35°C. Cooling fan on 20%.
Thanks!
Best Answer by FoxRun3D:
This is most likely example of the (in)famous bulge. 20+pages of discussions.
TL;DR: Many suggestions, no universally applicable solution.
To quote @bobstro:
Happily, this was described as a "buldge" in an early post and that misspelling has made the problem very easy to search for. There are several threads you might want to look through:
Thread one - Buldge when print reaches solid layers.( https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-how-do-i-print-this-printing-help/buldge-when-print-reaches-solid-layers/ )
Thread two - Any tips to get rid of the bulge? ( https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-how-do-i-print-this-printing-help/any-tips-to-get-rid-of-the-bulge/ )
Thread three - Mitigate wall bulge ( https://forum.prusa3d.com/forum/prusaslicer/mitigate-wall-bulge/ )
Publié : 15/06/2022 9:06 am
Membre
RE: Layer shifts at precise moment (ASA) - See pictures
This is usually an issue with one of the axes.  I have it in one direction periodically due to lubrication.  I lubricate and it goes way.  Check your XYZ and see if something is loose.
Publié : 15/06/2022 9:50 am
To quote @bobstro:
Publié : 15/06/2022 11:08 am
Tux
 Tux
(@tux-3)
Cheers, read through those for the most part and increasing the layer thickness from 0.68mm to 0.9mm solved the issue. Only some small bulge present directly next to the hole now!
Posted by: @fuchsr
To quote @bobstro:
Publié : 16/06/2022 3:22 pm
