How to fix GAPS on top shell
Steverd
(@steverd)
I need help in fixing these gaps on the top shells of these slugs.
I've tried many different settings and can not get this fixed (No gaps)
I've tried many Different Shell thickness top, Solid Layers Top, Vertical shell perimeters,
Would Classic Perimeter Generator work better than Arachne?
I need your help to get this dialed in - THANK YOU.
Here is my .3MF: TEST X2 SlugV1.1_wBrims 4 Inches
Respondido : 05/12/2022 7:15 pm
RE: How to fix GAPS on top shell
Try using a lower layer height, say 0.1 at least on the tops but probably overall would look better.  That will reduce the stair stepping and put more perimeters over the areas where your pic seems to show issues.  You could also try making your perimeter and external perimeter extrusion widths slightly thicker, like 0.5 -0.55mm too, but if you do that I would switch back to classic otherwise the arachne engine might still adjust them too much.
I think the layer height will give you the most change though.
Respondido : 05/12/2022 7:33 pm
Steverd me gusta
Steverd
(@steverd)
I will try that now - Thank you so much for the help.
Steve
Respondido : 07/12/2022 8:21 pm
Steverd
(@steverd)
I was able to fix this by changing the print size from 4.0 inch to 4.25 inch.
I am sure the .1mm layer height would've helped, but I didn't want my print time to go from 4.5 hrs to 9 hrs.
Thank you
Respondido : 12/12/2022 8:39 pm
