Y-axis bearing replacement
BeeMac
(@beemac)
So, tech support has been slow and not very helpful. I did get sent new bearings for the Y-axis, but was basically just told, “It’s easy, just take it apart and replace the bearings.”  Nothing about tools required or any other information.
 I followed the guide for replacing the heat plate but now I am stuck trying  to figure out how to remove the nuts holding the U-bolts. What size are the nuts? M5? Also once I get the front plate off, anything special about the removing the bearings?  When I put the plate back on, what about the belt tensioner?
Best Answer by Turro75:
remove the heatbed,
remove Y belt tensioner
disconnect display cable
remove front Y plate
take off the Y carriage
the U bolt are M3 5.5mm nuts
Place the new bearing oriented in a way that balls are not horizontal or vertical, they must be 45deg to ensure the best sliding. I use a pencil to draw a line that help me be sure it is not rotated
reassemble front plate ,tensioner and display
U bolts must be tightened equally on both sides (spanner key 5.5), be careful it must be tight to avoid the bearing rotating and moving along the rod, anyway too much pressure leads in a bad noise, move the ycarriage to ensure the movement is free of noise and smooth. You must do several trials.
Posted : 30/01/2021 6:20 pm
Turro75
(@turro75)
RE: Y-axis bearing replacement
remove the heatbed,
Posted : 31/01/2021 12:34 am
BeeMac
(@beemac)
@turro75
Thank you.  That was the guidance I needed
Posted : 19/02/2021 7:25 pm
