Underextrusion lines on outer walls
BIrwin
(@birwin)
I’ve been running into under‑extrusion issues on my print surfaces. The printer is an Original Prusa MINI from 2019, and it has generally been very reliable. I recently updated to the Input Shaper firmware, but I’m not entirely sure whether the problem started before or after that update.
To rule things out, I reprinted an older file that previously came out perfectly. The first print looked fine, but when I printed it again, it showed some under‑extrusion lines. Less noticeable than the Input Shaper print, but still there. The orange print is from before, and the blue one is after.
So far, I’ve replaced the nozzle, the entire hotend assembly, and both extruder gears, but the issue is still there.
Opublikowany : 21/03/2026 7:00 pm
_KaszpiR_
(@_kaszpir_)
RE: Underextrusion lines on outer walls
you can open up Prusa Slicer and load the gcode file (old one) and it should populate settings, you can then compare what was changed over the time.
Save current project as is, then go to Menu File > Import > Import Config and then see the differences.
I suspect increased retraction or some weird input shaper settings.
Opublikowany : 21/03/2026 8:36 pm
Have you replaced the PTFE tube?  If it is worn internally you might get a slip and grip sequence; that could explain the intermittent effect...
Opublikowany : 22/03/2026 11:41 am
BIrwin
(@birwin)
Yes, I have replaced this.
I thought I fixed it last night, by adjusting the Extruder Idler Screw. It was printing great for a few small prints. But halfway through my last print, the extruder just jammed and wouldn't print anything. I did a cold pull and it was clean.
Opublikowany : 22/03/2026 1:21 pm
