Tiny Filament stuck before motor
o.storjohann
(@o-storjohann)
Hi, my filament does not load after it broke, after dissasembling motor block i realized there is a tiny piece sttck just at the entrance to the motor block. I have tried to push it out from the motor side and the loading end with a wire, it does not move. i have found a lot of descriptions how to remove filament from the tube after the motor, and from the motor itselve. Unlike the second tube, it does not seem that the first tube is removeable from the motor?
Slightly desperate
Opublikowany : 09/10/2021 9:28 am
PTFE
That tube should be removable.
Opublikowany : 09/10/2021 11:44 pm
