Spare Parts
Mdavinci
(@mdavinci)
Spare Parts
I am just starting out with a Mini+. I don't want to be down for very long at a time unless I can't help it. What are some of the most common parts on the mini+ that break or wear out? If I can afford it, I would like to have spare parts on hand just in case any break or wear out.
Respondido : 02/08/2021 3:29 pm
Miembro
parts
Buy or print 1-2 fan shrouds and buy an extra hotend with some nozzles.  I also have 1-2 fans.
Respondido : 02/08/2021 4:01 pm
mark
 mark
(@mark)
PTFE Tubes
The printer comes with one extra PTFE tube that goes in the heatbreak. I now consider it a wear item. Get more. They are cheap if you order along with something else from Prusa. Maybe get an extra spring steel sheet plate. They get gouged with time. I generally order two rolls of filament and spare parts. Shipping for that is reasonable. I also got one of the only recently available silicone socks.
Regards,
Mark
Respondido : 02/08/2021 4:18 pm
1 les gusta
RE: Spare parts
Posted by: @mdavinci
-Hotend thermistor (100k)
-5V Printer fan (simple design, often breaks down)
-Nozzles
-some PTFE material (approx. 1m 4/2)
-PEI printing plate, smooth or textured
-fitting olives or PC4-M8x1.25 fittings
wbr,
Karl
Respondido : 02/08/2021 4:19 pm
Tracy
(@tracy)
My experience
In the 18 months I've owned my Mini, I've replaced:
  • Hotend PTFE tube (3 times)
  • Spring steel sheet (once - I unknowingly scratched up the bottom making it unusable)
  • Nozzle (once)
The bowden tube is probably the next thing I'll need to replace.
Respondido : 04/08/2021 7:57 pm
Mdavinci
(@mdavinci)
Thank You!
Thanks for all the tips on buying spare parts.
Respondido : 09/08/2021 3:01 pm
Miembro
order
Test the order with 2 rolls of filament.  It might reduce your shipping.
Respondido : 10/08/2021 12:00 am
