Prusa Mini with MK3S Extruder and Filament Runout Sensor
djkirkendall
(@djkirkendall)
So I had an idea a couple of days ago, why spend the cash on the Bondtech and external sensor for the Prusa Mini when the MK3S extruder has both?
I worked up the STL files, and the installation went really well. I now have a MK3S extruder and sensor in place, and everything appears to fit great.
I'm stuck on the firmware for the Mini, however. I pulled the git, and I have it compiling cleanly. I cut the appendix and uploaded the beta and all is well there.
Specifically, I'm having trouble finding:
1.) Invert filament sensor logic for MK3S:
    - I found filament_sensor.cpp:
typedef enum {
M600_on_edge = 0,
M600_on_level = 1,
M600_never = 2
} send_M600_on_t;
Q: Will this do it, or is there somewhere else to look? I'm in C:\Mini\Prusa-Firmware-Buddy-RELEASE-4.3.0\src
Secondly, I can't find a reference .h or .cpp for the mini (like configuration.h or the like that I'm used to seeing in other prusa/marlin folders) to change the e steps per mm to the needed 140. Anyone know where to change this at the firmware level?
I appreciate any help you good folks are willing to provide. Once I have the firmware up, tested & verified, and proven I'll share the extruder design up on thingiverse. All in all, the petg parts and gears/sensor only set me back about $25.
Postato : 14/02/2021 1:18 am
djkirkendall
(@djkirkendall)
RE: Prusa Mini with MK3S Extruder and Filament Runout Sensor
If anyone runs across this thread, here is the link: https://www.thingiverse.com/thing:4761746
I put the firmware up as well.  It works really well, and is super clean.
Enjoy!
Postato : 14/02/2021 5:02 am
Turro75
(@turro75)
Line 660 of the file
For the sensor idk
Postato : 14/02/2021 9:52 am
Turro75
(@turro75)
now I know, same file line 1002 to set filament sensor
Postato : 14/02/2021 10:13 am
djkirkendall
(@djkirkendall)
@turro75
I saw this too, but it looks like Prusa disbaled the Marlin filament runout sensor to make their own.
Best I can tell, they did it to allow for the event handlers to override from the front panel, and from the octoprint screen.
Postato : 14/02/2021 3:04 pm
NickRno77
(@nickrno77)
I’m trying to use the Mini Filament sensor for the MK3s, I cant Find anywhere to invert the IR Sensor, any ideas ?
https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/using-a-prusa-mini-filament-sensor-on-a-mk3s/
I’m using a E3D Hemera extruder which doesn’t have a filament sensor, I trying to use a Prusa Mini Filament sensor. Trouble is when filament is loaded the switch is set to 0 so I need to toggle this on the Firmware. I could redesign the filament sensor housing but ideally I’d like to do this in FW
Can somewhere point where and what to change in the firmware.
Thanks”
Questo post è stato modificato 5 years fa da NickRno77
Postato : 31/03/2021 6:06 pm
djkirkendall
(@djkirkendall)
From @karl-herbert
static void _cycle0() {
if (fSensor.read() == Pin::State::low) {
fSensor.pullDown();
status.meas_cycle = 1; //next cycle shall be 1
} else {
static void _cycle1() {
//pulldown was set in cycle 0
_set_state(fSensor.read() == Pin::State::low ? fsensor_t::HasFilament : fsensor_t::NotConnected);
fSensor.pullUp();
status.meas_cycle = 0; //next cycle shall be 0
Postato : 01/04/2021 1:11 am
djkirkendall
(@djkirkendall)
Original thread: https://forum.prusa3d.com/forum/user-mods-octoprint-enclosures-nozzles/prusa-mini-with-mk3s-extruder-filament-sensor/#post-371929
Postato : 01/04/2021 1:12 am
NickRno77
(@nickrno77)
Posted by: @djkirkendall
Thanks, for me I’m guessing the Mk3s firmware will be the opposite so I’ll need to change as follows? I may just make a sensor enclosure and pass the filament over the sensor directly doing away with the lever, magnets and ball  ? I’ll try this though
filament_sensor.cpp
original (line 212):
    if (gpio_get(PIN_FSENSOR) == 1) {
        gpio_init(PIN_FSENSOR, GPIO_MODE_INPUT, GPIO_PULLDOWN,            GPIO_SPEED_FREQ_VERY_HIGH); // pulldown
Postato : 01/04/2021 6:27 am
EpicMount
(@epicmount)
Found a way to get this to work in firmware version 4.3.3.
File: filament_sensor_photoelectric.cpp
Update the two functions FSensor::cycle0 and FSensor::Fcycle1 and switch HasFilament and NoFilament between the two functions.
Updated to flip the way the filament sensor reads should look like this:
void FSensor::cycle0() {
    if (FSensorPins::Get()) {
       FSensorPins::pullDown();
    } else {
        set_state(fsensor_t::HasFilament); //it is filtered, 2 requests are needed to change state
        meas_cycle = 0;                   //remain in cycle 0
void FSensor::cycle1() {
    set_state(FSensorPins::Get() ? fsensor_t::NoFilament : fsensor_t::NotConnected);
    FSensorPins::pullUp();
Postato : 25/11/2021 4:10 am
