Prusa Mini with MK3S Extruder and Filament Runout Sensor
So I had an idea a couple of days ago, why spend the cash on the Bondtech and external sensor for the Prusa Mini when the MK3S extruder has both?
I worked up the STL files, and the installation went really well. I now have a MK3S extruder and sensor in place, and everything appears to fit great.
I'm stuck on the firmware for the Mini, however. I pulled the git, and I have it compiling cleanly. I cut the appendix and uploaded the beta and all is well there.
Specifically, I'm having trouble finding:
1.) Invert filament sensor logic for MK3S:
- I found filament_sensor.cpp:
typedef enum {
M600_on_edge = 0,
M600_on_level = 1,
M600_never = 2
} send_M600_on_t;
Q: Will this do it, or is there somewhere else to look? I'm in C:\Mini\Prusa-Firmware-Buddy-RELEASE-4.3.0\src
Secondly, I can't find a reference .h or .cpp for the mini (like configuration.h or the like that I'm used to seeing in other prusa/marlin folders) to change the e steps per mm to the needed 140. Anyone know where to change this at the firmware level?
I appreciate any help you good folks are willing to provide. Once I have the firmware up, tested & verified, and proven I'll share the extruder design up on thingiverse. All in all, the petg parts and gears/sensor only set me back about $25.
RE: Prusa Mini with MK3S Extruder and Filament Runout Sensor
If anyone runs across this thread, here is the link: https://www.thingiverse.com/thing:4761746
I put the firmware up as well. It works really well, and is super clean.
Enjoy!
now I know, same file line 1002 to set filament sensor
@turro75
I saw this too, but it looks like Prusa disbaled the Marlin filament runout sensor to make their own.
Best I can tell, they did it to allow for the event handlers to override from the front panel, and from the octoprint screen.
I’m trying to use the Mini Filament sensor for the MK3s, I cant Find anywhere to invert the IR Sensor, any ideas ?
I’m using a E3D Hemera extruder which doesn’t have a filament sensor, I trying to use a Prusa Mini Filament sensor. Trouble is when filament is loaded the switch is set to 0 so I need to toggle this on the Firmware. I could redesign the filament sensor housing but ideally I’d like to do this in FW
Can somewhere point where and what to change in the firmware.
Thanks”
From @karl-herbert
static void _cycle0() {
if (fSensor.read() == Pin::State::low) {
fSensor.pullDown();
status.meas_cycle = 1; //next cycle shall be 1
} else {
static void _cycle1() {
//pulldown was set in cycle 0
_set_state(fSensor.read() == Pin::State::low ? fsensor_t::HasFilament : fsensor_t::NotConnected);
fSensor.pullUp();
status.meas_cycle = 0; //next cycle shall be 0
Original thread: https://forum.prusa3d.com/forum/user-mods-octoprint-enclosures-nozzles/prusa-mini-with-mk3s-extruder-filament-sensor/#post-371929
Thanks, for me I’m guessing the Mk3s firmware will be the opposite so I’ll need to change as follows? I may just make a sensor enclosure and pass the filament over the sensor directly doing away with the lever, magnets and ball ? I’ll try this though
filament_sensor.cpp
original (line 212):
if (gpio_get(PIN_FSENSOR) == 1) {
gpio_init(PIN_FSENSOR, GPIO_MODE_INPUT, GPIO_PULLDOWN, GPIO_SPEED_FREQ_VERY_HIGH); // pulldown
Found a way to get this to work in firmware version 4.3.3.
File: filament_sensor_photoelectric.cpp
Update the two functions FSensor::cycle0 and FSensor::Fcycle1 and switch HasFilament and NoFilament between the two functions.
Updated to flip the way the filament sensor reads should look like this:
void FSensor::cycle0() {
if (FSensorPins::Get()) {
FSensorPins::pullDown();
} else {
set_state(fsensor_t::HasFilament); //it is filtered, 2 requests are needed to change state
meas_cycle = 0; //remain in cycle 0
void FSensor::cycle1() {
set_state(FSensorPins::Get() ? fsensor_t::NoFilament : fsensor_t::NotConnected);
FSensorPins::pullUp();
