Klipper- There is no jumper on my board
Justin
(@justin)
I am wanting to try out Klipper on my Prusa Mini+ but when I check the directions it says to move a jumper on the board. There isn't one in sight so what do I do?
Also, will I be able to go back to the official Prusa firmware for this printer at a later time if I decide I'm no longer interested in Klipper or it doesn't work out for me?
Opublikowany : 27/05/2022 12:08 am
RE: Klipper- There is no jumper on my board
You might want to ask in Chat.  I doubt that they will be able to help since you moded your control board, but it is worth and ask.
Opublikowany : 27/05/2022 10:42 am
towlerg
(@towlerg)
Is this helpful https://help.prusa3d.com/article/flashing-custom-firmware-mini_14
Opublikowany : 27/05/2022 12:10 pm
This has already been discussed here:
https://forum.prusa3d.com/forum/postid/448699/
To change the firmware, you need to do a small board mod. Klipper can be removed at any time and the original FW can be installed.
wbr,
Karl
Opublikowany : 27/05/2022 11:58 pm
