Hotend heater cartridge - thermal paste
Vookimedlo
(@vookimedlo)
Hello,
I'd like to ask you if I am supposed to use the thermal paste while inserting the hotend heater cartridge into the hotend heaterblock?
Thanks,
Michal
Best Answer by JoanTabb:
Processor thermal paste will go like concrete in the heat block
Slice engineering offer Boron Nitride Paste    https://www.sliceengineering.com/products/boron-nitride-paste   Its expensive and I have never used it.
I have used Copaslip antisieze on the nozzle threads (I always catch the first extrusion after changing the nozzles, in a tissue so that the coppaslip does not get on the build plate,
I expect you could use copaslip  on the heater cartridge and thermistor cartridge
again, heat the hot end over a tissue pad, to ensure that nothing drips on the build plate
MOLYSLIP - COPASLIP | High Temperature Copper Anti-Seize Grease | Withstands Extreme Temperature (Up To 1100°C) | Protects Against Galling, Seizure Rust and Corrosion
available on Amazon, and in car spares shops
regards J0an
Veröffentlicht : 16/12/2022 11:17 am
mark
 mark
(@mark)
RE: Hotend heater cartridge - thermal paste
Posted by: @vookimedlo
Hello,
Thanks,
Michal
You should follow all these instructions precisely or results will not be satisfactory:
https://help.prusa3d.com/guide/how-to-replace-a-heaterblock-heatbreak-mini-mini_122769
It includes the thermal paste usage instructions as well as the dimensions and torque specs that should be used while assembling.
Regards,
Mark
Veröffentlicht : 16/12/2022 12:24 pm
regards J0an
Veröffentlicht : 16/12/2022 4:53 pm
