Auto leveling missing sheet at start
Macho burrito
(@macho-burrito)
Had a video but it was too big to attach. The issue I have is everything passes  calibration fine, but when I perform the auto leveling mesh the print head travels off the sheet and attempts to perform the auto leveling which fails. If I hold a tool at the sheet level the sensor detects the tool and moved to the next point in the sequence. How do I make it so the print head begins leveling at the proper point on the sheet?
Napsal : 03/08/2021 12:10 am
Take this to Prusa Support.
For support: Log into your Eshop account, navigate to support and live chat is at bottom right in most browsers. If not you may need to disable your ad-blocker temporarily.
Napsal : 03/08/2021 8:38 am
Macho burrito
(@macho-burrito)
thanks
Thanks, I was able to send an email, didn't see any option for live chat. Is it available during certain hours of the day?
Napsal : 04/08/2021 2:56 am
Login & be sure no adblockers are preventing chat from working
  1. Be sure you've logged in to the same account that you used to purchase your printer.
  2. Be sure you don't have any ad blockers (e.g., pihole) that could break chat.
Do those steps and you should see a support chat button.
Napsal : 04/08/2021 4:07 am
Chat button
Below is a map to the chat button:
Napsal : 04/08/2021 11:33 am
Macho burrito
(@macho-burrito)
solved
Issue solved the live chat person diagnosed that I didn't properly perform step 47 so the printer arm was too far forward on the machine. This is my first experience with a 3d printer so mistakes can and will happen. Now onto the first print layer calibration.
Napsal : 05/08/2021 4:05 am
1 lidem se líbí
BogdanH
(@bogdanh)
I'm glad your problem was solved by Prusa support and thank you for reporting.
[Mini+] [MK3S+BEAR]
Napsal : 05/08/2021 7:36 am
Enjoy
Good to hear.  Happy Printing!
Napsal : 05/08/2021 9:18 am
