PrusaLink Webpage not reachable
Hey there,
I just set up my Prusa MK4's Wifi. All seemed to work fine until I actually tried to get on the PrusaLink webpage. I entered the IP into my search bar and my tab shows me "PrusaLink", but nothing actually loads until I get an error message (just generic, look at the picture). When I ping that IP with the Command Prompt, it pings all fine and well. Other browsers (I use Firefox, tried Edge, Chrome) behave the same.
My conclusion: the printer works fine and is connected, but something either on my PC or in the network is blocking access.
Problem: I have no Idea what to do / try. I don't have access to the router/router settings but I probably could get it if that could fix the problem. I just don't know what the problem is and hope that some of you had it and figured it out already.
Cheers
I"m not exactly sure how Prusa Link works.. so forgive me if this suggestion is not technically accurate.. but can you set up a hotspot Wifi AP with your phone and try to get your computer & Printer attached to that.. then when the PrusaLink page tries to connect to Prusa to verify the Serial #, it should go out thru the hotspot which doesn't block anything.. That would tell you if your wifi/router is blocking something.
RE: PrusaLink Webpage not reachable
Read this link
https://kinsta.com/knowledgebase/err_connection_reset/
in a former life I worked a LOT with embedded webservers on devices laser jet printers, modems, etc..not saying this article is an answer to your connection reset..gives a couple things to try
Hey there,
Cheers
Hello, I'm new to the forum and I'm having the same problem. Did you find a solution?
For me, by default my browser was trying to go to https://[mylocalip], but needed to connect over http (no "s").
Hey there,
Cheers
