MK4 support for FlashAir needed
Antimix
(@antimix)
After reading all the mess around an issue affecting the PrusaLink wireless file transfer that often corrupt the gcode file during the wireless transfer on the IS 5.0.x firmware, I though to insert a FlashAir SD on the MK4, exactly like the one that I am using since years with zero issues on the MK3S.
But when I went on the LCD settings to set SD-type = FlashAir, I noticed that the settings is gone in the MK4 firmware 😣
I will do some tests to see if the MK4 will recognize just added/modified files via FlashAir or I will need to unplug & replug the FlashAir dongle each time a add a file.
- Anyone of you has tried to use FlashAir on the MK4 ?
Postato : 13/08/2023 8:28 pm
TeeBell
(@teebell)
RE: MK4 support for FlashAir needed
Yes, I tried using a FlashAir card in an adapter that plugs into the MK4 USB port. I could see the storage on my network but could not write to it. There are other threads here about this as well. I haven't tried in a few months so came back here to revisit posts and threads and saw yours first. Have you had any success?
Postato : 26/03/2024 1:19 pm
Antimix
(@antimix)
No, it does not work. The FlashAir is not supported on the MK4.
I switched to the PrusaLink, and for the moment I am happy with it. I use the original PRUSA USB. I will try also PrusaConnect.
Regards
Postato : 31/03/2024 3:14 pm
