Prusament Galaxy black out of spec
I am testing the Prusament Galaxy Black PLA and noticed inconsistent extrusion, so I am playing with the settings. I checked the filament diameter and it is consistently 1.66 mm, which is not thaaaaat bad, but also not within Prusament specs. I checked the spool specs and it says it is +-0.013, which should be between 1.737 and 1.763. Is it normal to see diameters smaller than what the filament measurements say?
Publié : 19/10/2019 4:04 am
RE: Prusament Galaxy black out of spec
And what are you measuring diameter with? Do you have a dimensional standard to check your tool accuracy?
Publié : 19/10/2019 8:43 am
