Missing notification for stuck filament
meltdown
(@meltdown)
Synopsis
When encountering a stuck filament issue, there's no PrusaConnect notification. The first alert is when the printer cools down due to inactivity.
General information:
PrusaLink type (Raspberry Pi Zero / Pi 3 / Pi 4)
MK4 built-in.
PrusaLink version
N/A, using built-in
Printer type
MK4 with MMU3
Printer UUID (you can find it in Printer detail page - address line)
84e8e2c2-f525-414d-aee2-b030df08e57e
Printer firmware version
6.2.6+8948
PrusaSlicer version (if applicable)
I believe this is not applicable, but 2.9.3.
Description of the bug, including steps to reproduce (if possible).
When there's a filament jam detected, the MK4 parks the printhead and waits for the user to confirm to unload/reload the filament. There is no notification generated by this step. If the printer is left unattended for a long time, heating will be disabled due to timeout, and there will be a notification when temperature drops below threshold - but that's the first notification. There is a notification generated *after* the filament reload before the print starts, but that's not necessary.
Steps to reproduce:
* Printer has issues with under-extrusion or other jamming
* Start a print
* Wait for the jam
Expected outcome:
* I receive an immediate notification to go to the printer and help with unjamming the filament
Actual outcome:
* I find out much later, after the printer has cooled down.
Veröffentlicht : 06/10/2025 7:06 pm
