[In evidenza] How to report bugs and errors
Jan Olejnik
(@jan-olejnik)
Utenti Admin
Before you submit a bug report, please use the Search function to make sure the bug hasn’t been already reported. If this is the first occurrence of the bug, add a new post to the Bugs & Errors forum and use a descriptive name for the topic. In case the bug has already been reported, feel free to add a reply in an existing topic with your own comment (e.g., you encountered the same bug but with slightly different behavior, etc.)
Your bug report should contain the following information:
  • PrusaLink type (Raspberry Pi Zero / Pi 3 / Pi 4)
  • PrusaLink version
  • Printer type
  • Printer UUID (you can find it in Printer detail page - address line)
  • Printer firmware version
  • PrusaSlicer version (if applicable)
  • Description of the bug, including steps to reproduce (if possible).
Questa discussione è stata modificata 5 years fa da Jan Olejnik
Prusa Research - Content Manager
Postato : 05/08/2021 2:19 pm
1 persone hanno apprezzato
SADan
(@sadan)
RE: How to report bugs and errors
I Read How to report bugs and errors and am honestly trying. I went through the first 6 pages and even searched importing old files and incorrect size old files
I'm a bit older and not sure I understand everything. I have been using a previous version for about 3 years but don't know what version it was after upgrading.
--- None that I know of.
PrusaLink version
--- Not Sure what that is but I upgraded to Version 2.7.2+win64
Printer type
--- Creality Creality Ender-5 Plus
--- No IDEA where that is nor how to find it ?
--- Version 2.7.2+win64
--- I have ONLY older files starting off with whatever version was out towards the ending of 2021.After upgrading to Version 2.7.2+win64 , When I import a stl file it shows up MUCH larger than it actually is. I have images and hope that helps.
Thank You for your time ,
Dan
Postato : 26/03/2024 12:21 pm
Tojik
(@tojik)
Utenti Moderator
Hi, you are in the Prusa Connect / PrusaLink section, that's why we want that info. It's fine.
Your model loaded 5x larger for whatever reason. No idea what unit mixup might have happened there. When you give it 0.2 in the scale in the bottom right, will it be exactly the right size?
Postato : 26/03/2024 1:42 pm
SADan
(@sadan)
Thank You so Much for getting back to me.  I apologize for being such a pain in the backside, but this new version is just to much for me to deal with right now.
I copied and pasted " 0.2 " and it did not work.  I loaded and retried it a few times thinking maybe I was doing something working ( again , Hahaha ) and it did the same thing.After trying a four different files and it still not working properly , I decided to uninstall and TRY to go back to0 version I had.
BIG mistake.
I was able to find the previous version I had on a deep dive into the drive it was named :
prusa3D_win_2_3_1.exe    and had a date / time stamp of 06-25-2021
IO was going to install the old one but wanted to make sure I got rig of all anything of the newer one so I went to RegEdit and searched for all / anything " Prusa " and deleted everything I could.  I believe I got most of it but I know there were some things I just wasn't going to let me get ride of.
So as it turns out after deleting all I could I rebooted , went back to Apps to see if it was there and it wasn't so I RE-installed older version.  It didn't work.  The Splash screen came up but it didn't Launch.  When I tried to uninstall it I got the message in Uninstalling Old ver.
Ive tried installing both versions a few times.   I now get the image named PRUSA ERROR , so I'm at point now I'm unsure what to do.
I DO understand y'all are busy and all , but ANY information you need , I'd be more than happy to provide.
Respectfully ,
Dan
Postato : 27/03/2024 7:02 am
Lukáš Matěna
(@lukas-matena)
Utenti
Hi Dan,
I am not sure I understand the sequence of events correctly, but I understand you had three different issues:
1. After upgrading to 2.7.2, your objects were being loaded larger than you wanted. This is difficult to solve without seeing the files, but based on what I see in the right panel, I suspect that you were loading an STL in the old version, while you use a 3MF in the new. The 3MF may contain some transformations which you do not expect and consider it an error.
2. You are getting the "set_deserialize failed" errors when you try to run the old version. This is because there are profiles the old version is not compatible with, and it is unable to cope. If you use 2.3.2 instead of 2.3.1, it should be better, because some forward-compatibility handling rules were added in that version. Another option is to delete the configuration folder (in AppData/Roaming/PrusaSlicer), but this will remove any user profiles that you may have created, so do it only if you are sure you will not lose anything precious (and better backup the folder, just in case).
3. The installer reports errors when trying to uninstall some old version. This may be triggered by the manual registry tweaks that you mention. Anyway, you don't really need to install the software. Simply download the ZIP archive from our github releases page, choose a version that you like (I recommend the latest stable, i.e. 2.7.2), download the archive for Windows (there is an Assets dropdown at the end of each release block), unzip it wherever you like and run prusa-slicer.exe.
Has any of that helped?
Questo post è stato modificato 2 years fa da Lukáš Matěna
Lukas Matena
PrusaSlicer development
Postato : 27/03/2024 11:27 am
SADan
(@sadan)
THANK YOU !!!
As an older person who is doing what he can to keep up with his Family on so many things , THIS has been one of my FAVORITE inside computer related things to do.  When I upgraded without KNOWING what I was doing , and then having the issues that I CAUSED , I reached out and was honestly SURPRISED at such a quick response.
Not only were you able to help me get back to the version I was use to , but I did a trial and error and was even able to upgrade a bit ( grin ) and STILL be comfortable with knowing ( hahahaha ,  somewhat ) of what I was doing.THANK YOU !!!   For getting me back to a place that I am happy at.
IF there is something I can do to help y'all in ANY MANNER , PLEASE let me know.    If you would like me to donate to y'all , your favorite charity , PLEASE let me know.   I am not rich in any manner of the word , other than FAMILY , and YOU just helped me, help the ones I Love...
THANK YOU ,
Respectfully ,
Dan
Postato : 31/03/2024 8:13 am
Tojik
(@tojik)
Utenti Moderator
Hey, glad it's working for you. It's not an ideal solution, but it's great you can keep doing what you want to be doing. Some people yell at us on here when their stuff breaks. Thank you for being a good sport about it. Feel free to ask for help any time.
And sorry for the cryptic 0.2 scale factor. I should have used a percent value (20%) when describing what to scale the object by. I didn't check what units is Slicer using.
I wish you many successful prints
Postato : 02/04/2024 8:43 am
SADan
(@sadan)
I wanted to do a follow up to give you the good news.
I have had several successful prints , and I'm understanding more and more.   It takes me a bit but I think I'm getting the hang of it.
I'm starting to TRY to play with the supports ( I think they are called Tree supports ) but gonna look for a youtube video to help me get a better grasp on the " HOWS " when using them...
Hope y'alls day is going well
Dan
Postato : 30/05/2024 5:37 pm
BitSmith
(@bitsmith)
Could "5x" the size have something to do with a setting?  I've noticed that when loading smaller parts, I'm asked a question something like "Convert mm to inches?"  I wonder if that's an issue.  I NEVER want to do that - and would like to find a setting to disable that automatic help.
Please advise...
Postato : 19/07/2024 5:04 pm
alkas
(@alkas)
Utenti
High CPU usage in browser
PrusaLink type (Raspberry Pi Zero / Pi 3 / Pi 4): Na
PrusaLink version: Na
Printer type: Prusa Mini+
Printer UUID (you can find it in Printer detail page - address line): 7343bf5c-3e81-4866-97ef-434cd435995c
Printer firmware version: 6.1.2+7894
PrusaSlicer version (if applicable): 2.8.1
Description of the bug, including steps to reproduce (if possible):
Just having a tab open on 'Printer files' page constantly draws about 15-20% CPU (Windows 10, 6 core Ryzen 7600x). Both Google Chrome and Firefox exhibits this behaviour. Other pages like 'Dashboard' does not use measurable CPU when loaded.
Questo post è stato modificato 2 years fa da alkas
Postato : 21/09/2024 11:56 am
TRT-3D-Printers
(@trt-3d-printers)
Utenti
Prusa Connect material error when filename contains "PC"
PrusaLink type (Raspberry Pi Zero / Pi 3 / Pi 4): N/A
PrusaLink version: N/A
Printer type: Prusa XL
Printer UUID: a75a9365-b686-44db-ad4c-eed22fe028ea
Printer firmware version: 6.2.5+8912
PrusaSlicer version (if applicable): 2.9.2
Description of the bug:
I noticed that I was occasionally getting 'incorrect material' errors despite having all settings in both the slicer and printer set to PLA material.
I figured out that if the filename contains the letters "PC" anywhere, the material on Prusa Connect gets flipped to PC.
Below is a screenshot showing that by varying only the filename, I could replicate the error anytime the letters' PC' appeared in the filename.
Thanks,
Tim
Postato : 02/07/2025 10:16 pm
nwk23
(@nwk23)
Utenti
Print time error
PrusaConnect
MK4S
8f04ac43-bab5-4fe2-ba75-529bc3cf53516.2.6+8948
Prusaslicer 2.9.3
I was comparing the print time of a model with 2 different infils and noticed the estimated finish times didn't make sense. The version with 15% infil would spend 24 minutes printing infill and take 3:41, but the model with 30% infill would spend 43 minutes on infill but would take 4:26 to complete.  Going to 30% infil should only add about 20 minutes, but the total print time is almost 40 minutes longer. Then when I started adding up the times, they didn't come close to the total time.  I think the time calculation is bugged.
I've attached a link to a Box folder with screen caps of the two slices and the .3mf
Postato : 07/11/2025 1:19 pm
boecko
(@boecko)
Utenti
i've reported a bug in the "Prusa Connect"-webapp.
"Steel sheet was not detected. Please put the sheet on to prevent printer damage."
https://forum.prusa3d.com/forum/bugs-errors/connect-reports-wrongfully-steel-sheet-was-not-detected-please-put-the-sheet-on-to-prevent-printer-damage/
Why was it removed without giving me a feedback?
Did I miss something?
an irritated customer
Postato : 29/01/2026 1:42 pm
Hi Boecko
I will pass this up to my Prusa contact,   in the meantime,
I have had this issue a couple of times, with My Mk4S printer.
On my printer, if the buildplate is a tiny bit displaced to the right,  I get this message,
Is it possible that you have  a similar issue?
Regards Joan
Postato : 29/01/2026 4:00 pm
boecko
(@boecko)
Utenti
Hi Joan,
thanks for the reply
Posted by: @joantabb
Hi Boecko
Regards Joan
No .. the buildplate is correctly mounted,  Autohome is working and the printer is happily printing.
It would have stopped with an error on the printer-LCD if this would be the issue, btw..
The prusaapp doesn't show the error either. Just PrusaConnect with an TYPO btw 😀 (STEEL SHEEL). The error comes via websocket. (see second picture)
kind regards
boecko
Postato : 29/01/2026 4:27 pm
bryn51
(@bryn51)
Its all very well telling people to use the search function when wanting to make a report, but in fact the search function itself is not at all smart, and its precise about words used. So even if you search, and there's an existing pst, its not found.  Please pay attention to putting an AI based search tool on the forum.
Posted by: @jan-olejnik
  • PrusaLink version
  • Printer type
Postato : 21/04/2026 12:10 am
