[Resuelto] Prusa Mini+ Failing Initial Testing (XYZ Axis)
Mataos
(@mataos)
Video for reference:
Before the first test, the Z axis was stationed at the top. Now, however, it is stuck at the bottom and does not go up - after it attempted the first set up where it was testing common assembly faults. The X and Y axis testing was okay in the first attempt, however, since the Z axis test fail, all axis' are failing the tests - as nothing can move due to it being 'stuck' at its lowest possible point (even below the heatbed). The Z axis part was also resting on top of the heatbed (applying pressure to it as it was that low), so I pushed the heatbed out of the way with a bit of a push to avoid it being damaged.
Cheers
*repost with updated link and information*
Best Answer by Turro75:
check here https://help.prusa3d.com/en/guide/2-yz-axis-assembly_196824   at step 47, I think Your Z axis is assembled in the wrong position.
Este debate ha sido modificado el hace 5 years por Mataos
Respondido : 01/03/2021 8:38 pm
Turro75
(@turro75)
RE: Prusa Mini+ Failing Initial Testing (XYZ Axis)
the bed level sensor reads the rod instead of the plate.
Turn off the printer, manually raise up the z axis until mid of its vertical range and retry.
Respondido : 01/03/2021 11:04 pm
Mataos
(@mataos)
@turro75
How do I raise the z axis? Sorry, very new to this, first machine and only had for a day.
Mataos
Respondido : 02/03/2021 5:53 am
Turro75
(@turro75)
switch off the printer then turn the z axis leadscrew by hand, this will move up or down the z carriage
Respondido : 02/03/2021 6:56 am
Mataos
(@mataos)
@turro75
No success, same issue. Pulled it up about halfway, testing for x and y were successful, but the z proceeded to continue down until it was the same as what's shown in the video.
Respondido : 02/03/2021 11:26 am
Turro75
(@turro75)
Respondido : 02/03/2021 8:37 pm
Mataos
(@mataos)
@turro75
Thank you Turro, ended up going back through the booklet and noticed that it was attached exactly to the bump - leaving it out of line. Problem solved!
Respondido : 03/03/2021 9:25 am
