RE: Major issue with first level
Sounds line the bed is not level, though it is hard to tell with the attached photo
Electronics Technician / Computer Programmer
Postato : 29/12/2020 8:17 pm
1 persone hanno apprezzato
If the lines of the first layer do not stick together, you should do another first layer calibration. It looks like your Nozzel is too far away from the bed. https://help.prusa3d.com/en/article/first-layer-calibration_112364
If the problem only occurs in some parts of the bed, check that the bed is flat. Put the edge of a straightedge on the bed and you should see an even little gap between the bed and the straightedge.
Postato : 29/12/2020 9:01 pm
Or maybe an intermittent clog?
Postato : 30/12/2020 11:16 am
