Major issue with first level
Jonathan Koubler
(@jonathan-koubler)
For some reason, the first layer lines won’t stick to eachother or the second layer except on one side. If anyone has any advice it would be useful to know. I am printing with PLA using a 0.4 mm nozel and slicing my models on prusaslicer.
Opublikowany : 29/12/2020 7:25 pm
Roberts_Clif
(@roberts_clif)
RE: Major issue with first level
Sounds line the bed is not level, though it is hard to tell with the attached photo
Electronics Technician / Computer Programmer
Opublikowany : 29/12/2020 8:17 pm
Achiles
(@achiles)
If the lines of the first layer do not stick together, you should do another first layer calibration. It looks like your Nozzel is too far away from the bed.  https://help.prusa3d.com/en/article/first-layer-calibration_112364
If the problem only occurs in some parts of the bed, check that the bed is flat. Put the edge of a straightedge on the bed and you should see an even little gap between the bed and the straightedge.
Opublikowany : 29/12/2020 9:01 pm
towlerg
(@towlerg)
Or maybe an intermittent clog?
Opublikowany : 30/12/2020 11:16 am
