Heatbed is shaking when it moves forward but only on diagonals.
[Rozwiązany] Heatbed is shaking when it moves forward but only on diagonals.
max
 max
(@max-11)
Two sides (facing right front and right rear corners) came out with waves. Is it expected or my printer needs an alignment? This is a new MINI+ purchased as semi-assembled. I can see the heatbed shaking when these 2 sides are printed. it happens only on diagonals and when the heatbed moves forward.
Best Answer by max:
Upon additional investigation I found that Y axis belt was not tensioned at all.
Opublikowany : 22/01/2022 7:05 am
max
 max
(@max-11)
RE: Heatbed is shaking when it moves forward but only on diagonals.
Opublikowany : 22/01/2022 6:28 pm
