First layer separates from steel plate when printing
milind.gupta
(@milind-gupta)
Hello,
         I just assembled my brand new Prusa Mini. I am totally new to 3D printing. I am trying to print the Whistle model in the USB drive that came with it. It starts printing it and prints a first layer and then the plate starts moving a little more rapidly at which point the 1st layer separates from the steel plate and sticks to the nozzle.
        How do I solve this? I thought maybe raising the heatbed temperature may help. I raised it from 60 to 66 but still the same thing happened. Please help me fix this.
Thanks,
Milind
Opublikowany : 13/09/2020 12:26 am
RE: First layer separates from steel plate when printing
Posted by: @milind-gupta
Hello,
Thanks,
Milind
Hello and welcome to the Prusaforum!
It's important that the printing bed is clean before you start printing. To clean, use a grease-dissolving detergent, rinse with plenty of water and dry with a lint-free cloth. Then do not touch the printing surface with your fingers. If necessary, wipe with isopropanol.
The First Layer must also be well adjusted. Here is a good explanation:
and here:
https://help.prusa3d.com/en/article/first-layer-calibration_112364
good luck!
Opublikowany : 13/09/2020 12:47 am
milind.gupta
(@milind-gupta)
@karl-herbert
Thanks! That worked.
Opublikowany : 13/09/2020 1:41 am
@milind-gupta
Great!
Did you carry out both procedures or was the cleaning of the printing bed sufficient?
Opublikowany : 13/09/2020 10:43 am
milind.gupta
(@milind-gupta)
I had cleaned it before as well. Did it again. Had to adjust the nozzle offset negative.
Opublikowany : 13/09/2020 3:39 pm
@milind-gupta
thanks for the feedback and...
happy printing 👍
Opublikowany : 13/09/2020 4:08 pm
