Prusa Mini with MK3S Extruder/Filament Sensor
djkirkendall
(@djkirkendall)
So I had an idea a couple of days ago, why spend the cash on the Bondtech and external sensor for the Prusa Mini when the MK3S extruder has both?
I worked up the STL files, and the installation went really well. I now have a MK3S extruder and sensor in place, and everything appears to fit great.
I'm stuck on the firmware for the Mini, however. I pulled the git, and I have it compiling cleanly. I cut the appendix and uploaded the beta and all is well there.
Specifically, I'm having trouble finding:
1.) Invert filament sensor logic for MK3S:
    - I found filament_sensor.cpp:
typedef enum {
M600_on_edge = 0,
M600_on_level = 1,
M600_never = 2
} send_M600_on_t;
Q: Will this do it, or is there somewhere else to look? I'm in C:\Mini\Prusa-Firmware-Buddy-RELEASE-4.3.0\src
Secondly, I can't find a reference .h or .cpp for the mini (like configuration.h or the like that I'm used to seeing in other prusa/marlin folders) to change the e steps per mm to the needed 140. Anyone know where to change this at the firmware level?
I appreciate any help you good folks are willing to provide. Once I have the firmware up, tested & verified, and proven I'll share the extruder design up on thingiverse. All in all, the petg parts and gears/sensor only set me back about $25.
Respondido : 14/02/2021 12:30 am
RE: Prusa Mini with MK3S Extruder/Filament Sensor
Posted by: @djkirkendall
typedef enum {
M600_on_edge = 0,
M600_on_level = 1,
M600_never = 2
} send_M600_on_t;
Prusa Mini invert Sensor logic:
filament_sensor.cpp
original (line 212):
static void _cycle0() {
    if (gpio_get(PIN_FSENSOR) == 1) {
        gpio_init(PIN_FSENSOR, GPIO_MODE_INPUT, GPIO_PULLDOWN,            GPIO_SPEED_FREQ_VERY_HIGH); // pulldown
        status.meas_cycle = 1;                                                             //next cycle shall be 1
modified:
    if (gpio_get(PIN_FSENSOR) == 0) {
original (line 244):
//called only in fs_cycle
static void _cycle1() {
    //pulldown was set in cycle 0
    _set_state(gpio_get(PIN_FSENSOR) == 1 ? FS_HAS_FILAMENT : FS_NOT_CONNECTED);
    gpio_init(PIN_FSENSOR, GPIO_MODE_INPUT, GPIO_PULLUP, GPIO_SPEED_FREQ_VERY_HIGH); // pullup
    status.meas_cycle = 0;                                                           //next cycle shall be 0
modified:
    _set_state(gpio_get(PIN_FSENSOR) == 0 ? FS_HAS_FILAMENT : FS_NOT_CONNECTED);
Prusa Mini change esteps:
Configuration_A3ides_2209_MINI.h
original:
* Default Axis Steps Per Unit (steps/mm)
 * Override with M92
 *                                      X, Y, Z, E0 [, E1[, E2[, E3[, E4[, E5]]]]]
//#define DEFAULT_AXIS_STEPS_PER_UNIT   { 100, 100, 400, 280 } //E0 280 295
#define DEFAULT_AXIS_STEPS_PER_UNIT \
    { 100, 100, 400, 325 } //E0 280 295
//#define DEFAULT_AXIS_STEPS_PER_UNIT   { 800, 800, 3200, 1120 } //E0 280 295
//#define DEFAULT_AXIS_STEPS_PER_UNIT   { 100, 100, 400, 1120 } //E0 280 295
modified:
 * Override with M92
{ 100, 100, 400, 140 } //E0 280 295 // E -> 140=8 microsteps (280=16 microsteps)
Respondido : 14/02/2021 1:38 am
djkirkendall
(@djkirkendall)
@karl-herbert
The new firmware syntax is a little different, but the approach was the same:
if (fSensor.read() == Pin::State::low) {
fSensor.pullDown();
} else {
_set_state(fSensor.read() == Pin::State::low ? fsensor_t::HasFilament : fsensor_t::NotConnected);
fSensor.pullUp();
I compiled, uploaded, and tested the new firmware and it checks GOOD! Thanks for the help. I've attached the resultant .bbf for anyone that wants to follow this. I'll put the link to TVerse here in a few.
Respondido : 14/02/2021 4:46 am
djkirkendall
(@djkirkendall)
If anyone runs across this thread, here is the link: https://www.thingiverse.com/thing:4761746
I put the firmware up as well.
Enjoy!
Respondido : 14/02/2021 5:01 am
@djkirkendall
This is quite possible. I have made these and other changes in 4.2.0. But I hope that this still helped.
A small correction to the following line:
I increased E from 16 to 32 microsteps (not from 8 to 16 as stated). Currently X/Y/E=32 microsteps, Z=16 microsteps
Interesting project and thanks for making it available in Thingiverse 👍
Respondido : 14/02/2021 12:45 pm
pear3d.ch
(@pear3d-ch)
Hi Guys,
i am runing mk3s extruder since a while:
The project is here: https://www.prusaprinters.org/prints/37939-prusa-mini-mk3s-bear-ultra-upgraded
Best Regards
Respondido : 15/02/2021 9:50 am
2 les gusta
@3dpgva
Well done 👍
The new MK-Mini so to speak 😊
Respondido : 15/02/2021 12:00 pm
djkirkendall
(@djkirkendall)
@3dpgva
Neat!!
I was looking to eat Bondtech's lunch with my design.
Respondido : 15/02/2021 5:28 pm
djkirkendall
(@djkirkendall)
@3dpgva
Neat!!
3DEMS
(@3dems)
Im having trouble finding this on Firmware 4.3.3
Can someone help me please?
 * @file filament_sensor.cpp
 * @author Radek Vana
 * @date 2019-12-16
#include "filament_sensor.hpp"
#include "print_processor.hpp"
#include "fsensor_eeprom.hpp"
#include "rtos_api.hpp"
//singleton
FSensor &FS_instance() {
    static FSensor ret;
    return ret;
FSensor::FSensor()
    : state(fsensor_t::NotInitialized)
    , last_state(fsensor_t::NotInitialized)
    , meas_cycle(0)
    , event_lock(0) {
    PrintProcessor::Init();
//debug functions
bool FSensor::WasM600_send() {
    CriticalSection C;
    return status.M600_sent;
char FSensor::GetM600_send_on() {
    switch (status.send_event_on) {
    case inject_t::on_edge:
        return 'e';
    case inject_t::on_level:
        return 'l';
    case inject_t::never:
        return 'n';
    return 'x';
//simple filter
//without filter fs_meas_cycle1 could set FS_NO_SENSOR (in case filament just runout)
void FSensor::set_state(fsensor_t st) {
    CriticalSection C;
    if (last_state == st)
        state = st;
    last_state = st;
//global thread safe functions
fsensor_t FSensor::Get() {
    return state;
//value can change during read, but it is not a problem
bool FSensor::DidRunOut() {
    return state == fsensor_t::NoFilament;
void FSensor::M600_on_edge() {
    CriticalSection C;
    status.send_event_on = inject_t::on_edge;
void FSensor::M600_on_level() {
    CriticalSection C;
    status.send_event_on = inject_t::on_level;
void FSensor::M600_never() {
    CriticalSection C;
    status.send_event_on = inject_t::never;
//but cannot be called from interrupt
void FSensor::Enable() {
    CriticalSection C;
    enable();
    FSensorEEPROM::Set();
void FSensor::Disable() {
    CriticalSection C;
    disable();
    FSensorEEPROM::Clr();
FSensor::inject_t FSensor::getM600_send_on_and_disable() {
    CriticalSection C;
    inject_t ret = status.send_event_on;
    return ret;
void FSensor::restore_send_M600_on(FSensor::inject_t send_event_on) {
    CriticalSection C;
    //cannot call init(); - it could cause stacking in uninitialized state
    status.send_event_on = send_event_on;
fsensor_t FSensor::WaitInitialized() {
    fsensor_t ret = FSensor::Get();
    while (ret == fsensor_t::NotInitialized) {
        Rtos::Delay(0); // switch to other threads
    return ret;
void FSensor::ClrM600Sent() {
    CriticalSection C;
    status.M600_sent = false;
void FSensor::ClrAutoloadSent() {
    CriticalSection C;
    status.Autoload_sent = false;
uint32_t FSensor::DecEvLock() {
    CriticalSection C;
    if (event_lock > 0)
        --event_lock;
    return event_lock;
uint32_t FSensor::IncEvLock() {
    CriticalSection C;
    return ++event_lock;
//global not thread safe functions
void FSensor::init() {
    bool enabled = FSensorEEPROM::Get();
    if (enabled)
        enable();
    else
        disable();
void FSensor::InitOnEdge() {
    init();
    FSensor::M600_on_edge();
void FSensor::InitOnLevel() {
    init();
    FSensor::M600_on_level();
void FSensor::InitNever() {
    init();
    FSensor::M600_never();
//methods called only in fs_cycle
//M600_on_edge == inject after state was changed from HasFilament to NoFilament
//M600_on_level == inject on NoFilament
//M600_never == do not inject
void FSensor::evaluateEventConditions(event ev) {
    if (isEvLocked())
        return;
    //M600
    if (((status.send_event_on == inject_t::on_edge && ev == event::EdgeFilamentRemoved)
            || (status.send_event_on == inject_t::on_level && ev == event::NoFilament))
        && !status.M600_sent
        && PrintProcessor::IsPrinting()) {
        status.M600_sent = true;
        PrintProcessor::InjectGcode("M600"); //change filament
    //autoload
    if (((status.send_event_on == inject_t::on_edge && ev == event::EdgeFilamentInserted)
            || (status.send_event_on == inject_t::on_level && ev == event::HasFilament))
        && (!status.Autoload_sent)
        && PrintProcessor::IsAutoloadEnabled()
        && !PrintProcessor::IsPrinting()) {
        status.Autoload_sent = true;
        PrintProcessor::InjectGcode("M1400 S65"); //load with return option
FSensor::event FSensor::generateEvent(fsensor_t previous_state) const {
    const bool has_filament = fsensor_t::HasFilament == state;
    const bool had_filament = fsensor_t::HasFilament == previous_state;
    if (has_filament == had_filament)
        return has_filament ? event::HasFilament : event::NoFilament;
    /// state has changed
    if (has_filament)
        return event::EdgeFilamentInserted; //has && !had
    return event::EdgeFilamentRemoved;      //!has && had
//delay between calls must be 1us or longer
void FSensor::Cycle() {
    volatile const fsensor_t last_state_before_cycle = state;
    //sensor is disabled (only init can enable it)
    if (last_state_before_cycle == fsensor_t::Disabled) {
        return;
    cycle();
    event ev = generateEvent(last_state_before_cycle);
    evaluateEventConditions(ev);
Respondido : 04/02/2022 5:00 pm
Zoltan
(@zoltan-d-2)
Miembro Moderator
3DMYG
Not sure what do you want to do with it, but for master try here https://github.com/prusa3d/Prusa-Firmware-Buddy/blob/master/src/common/filament_sensor.cpp
and for  4.3.3 release here https://github.com/prusa3d/Prusa-Firmware-Buddy/blob/RELEASE-4.3.3/src/common/filament_sensor.cpp
Respondido : 04/02/2022 6:03 pm
MysDawg
(@mysdawg)
Neat idea
Respondido : 05/02/2022 4:27 pm
singlefin
(@singlefin)
Hi
@djkirkendall, @karl-herbert or anyone else who has successfully modified firmware to invert filament sensor, I just completed my Mini Bear conversion and everything works as intended except the Mini's filament sensor.  I have compiled my own firmware for the Bear Mini with some features to suit the Bear.  I tried to invert the filament sensor logic in the Configuration_Mini.h file in /include/marlin but didn't work.  The sensor value returns 1 while no filament, and 0 with filament inserted.
Then I found this post and trying to alter the firmware code in what I assume to be the corresponding file that was referenced in posts above.  The new file name in 4.4.1 is called filament_sensor_photoelectric.cpp in the /src/common folder.  The code in the latest firmware version seem different than prior versions above.  I don't understand C++ so I'm asking for help to change the code in order to invert the Filament Sensor logic properly.
Thanks!
 * @file filament_sensor_photoeletric.cpp
 * @date 2021-02-12
//there is 10kOhm PU to 5V in filament sensor
//MCU PU/PD is in range 30 - 50 kOhm
//when PD is selected and sensor is connected Vmcu = min 3.75V .. (5V * 30kOhm) / (30 + 10 kOhm)
//pin is 5V tolerant
//MCU has 5pF, transistor D-S max 15pF
//max R is 50kOhm
//Max Tau ~= 20*10^-12 * 50*10^3 = 1*10^-6 s ... about 1us
#include "filament_sensor_photoeletric.hpp"
#include "fsensor_pins.hpp"
static volatile fsensor_t last_state = fsensor_t::NotInitialized;
void FSensor::cycle0() {
    if (FSensorPins::Get()) {
        FSensorPins::pullDown();
    } else {
        set_state(fsensor_t::NoFilament); //it is filtered, 2 requests are needed to change state
        meas_cycle = 0;                   //remain in cycle 0
void FSensor::cycle1() {
    set_state(FSensorPins::Get() ? fsensor_t::HasFilament : fsensor_t::NotConnected);
    FSensorPins::pullUp();
void FSensor::cycle() {
    if (meas_cycle == 0) {
        cycle0();
    } else {
        cycle1();
void FSensor::enable() {
    meas_cycle = 0;
void FSensor::disable() {
    state = fsensor_t::Disabled;
    last_state = fsensor_t::Disabled;
    meas_cycle = 0;
//not recorded
void FSensor::record_state() {
//simple filter
    CriticalSection C;
        state = st;
    last_state = st;
Esta publicación ha sido modificada el hace 3 years 3 veces por singlefin
Respondido : 22/01/2023 12:10 pm
For 4.2.0 I made following changes (marked blue and red):
\Prusa-Firmware-Buddy-RELEASE-4.2.0\src\common\filament_sensor.cpp
original (Zeile 212):
geaendert:
original (Zeile 244):
geaendert:
Thus, at least the status is correctly displayed, but unfortunately no outgoing filament is detected (pullup=0, pulldown=1). I can live with that 😊
wbr,
Karl
Respondido : 22/01/2023 12:46 pm
singlefin
(@singlefin)
@karl-herbert Thank you for replying and helping.  I was able to find another post that showed where to change code for a later version of the firmware, similar to 4.4.1.  I just compiled firmware with the changes and filament sensor works properly now.
Thanks!
Respondido : 22/01/2023 2:16 pm
singlefin
(@singlefin)
By the way, in case anyone else was looking to do the same, I referenced a post written by user EpicMount (last posting in the thread as of now) here: https://forum.prusa3d.com/forum/hardware-firmware-and-software-help/prusa-mini-with-mk3s-extruder-and-filament-runout-sensor/
I got this to work with Firmware 4.4.1 on my Mini Bear.
Respondido : 22/01/2023 2:19 pm
Thanks for reply and happy printing 👍
wbr,
Karl
Respondido : 22/01/2023 2:56 pm
