Nozzle Compatibility
PeanutButte7
(@peanutbutte7)
Is the official nozzle compatible with Mini? Might be a stupid question but Mini is not listed on the page while other printers are.
https://shop.prusa3d.com/en/i3-accessories-mk3s-mk25s-etc/89-nozzle-e3d-v6.html?search_query=nozzle&results=9#/15-nozzle_diameter-06mm
Opublikowany : 04/01/2020 6:52 pm
RE: Nozzle Compatibility
Hi Adam,
do you have your Mini Yet?
Prusa normally only allow you to see parts for printers that you have bought.
Might be worth having a word with Support.
From a purely logistical point of view, it would make sense for Prusa to use the same nozzles as the other printers in the range, but that is no guarantee that the did do so!
hopefullt an owner of both Mini and Mk1, Mk2 or mk3, can answer your question factually.
Opublikowany : 05/01/2020 2:34 am
Olef
 Olef
(@olef)
FYI there are no nozzles listed at all under Mini spare parts currently.
Opublikowany : 05/01/2020 9:44 am
Oxygen
(@oxygen)
And keep in mind that you only can see the spare parts of the MINI if you have your mini delivered to your house. If I look in the store I do not see any parts of the MINI (PR said they are looking into that)
Stock MK4S with FW 6.2.6
Opublikowany : 05/01/2020 10:17 am
Petzon
(@petzon)
Yes it is the same nozzle for mini as for I3 mk 2/3, theE3D V6 nozzle
Opublikowany : 05/01/2020 10:46 am
Aaron
(@aaron)
Posted by: @oxygen
I have the mini at home and can confirm that there are no nozzles listed for it on the site. It looks like the E3D V6, but I haven't unscrewed it to confirm yet, but yeah people are saying it is.
Opublikowany : 06/01/2020 2:01 am
Aaron
(@aaron)
Ah, looking at the spare fully assembled hot-end for the mini in the spare parts section:
  • Nozzle V6 (Diameter: 0.4 mm) (1 pcs)
Opublikowany : 06/01/2020 2:08 am
Texy
 Texy
(@texy)
Basically they have listed the Mini specific parts, but not added Mini tagging to those parts used on more than one model.
Texy
Opublikowany : 07/01/2020 2:19 pm
