MINDA saver mods tried
Sfbrain
(@sfbrain)
Hi Guys
For info I have tried a couple of the 'MINDA saver' mods that have appeared on 'Prusa Prints' and 'Thingverse'
These are the parts i printed
The top cover for the electronics box swaps over the cable exits for the two big cable bunches, moving the X-Axis cables closer to the extruder head
The other mod removes the cable from being directly tie-wraped to the extruder motor block.
The shaft replaces the cable against the motor block and its lower element moves the cable over, at an angle towards the extruder head
The only thing i have noted is that the wires that come out of the cable bundle to drive the extruder motor gears hang down and will rub against the print sheet when at the lower settings of the extruder.
They can easily be moved slightly up to avoid this.
I can confirm these mods do work and there is more 'slack' in the cable bundle leading to the extruder head.
My MINI is now printing fine after fitting these mods.
(Sorry about the orange prints, it was the only PETG i had available 😉 )
S
Respondido : 07/01/2020 10:09 am
3Dprintedgr
(@3dprintedgr)
RE: MINDA saver mods tried
Thanks for the update. I wonder if Prusa is going to implement some of these edits on the printers that are being manufactured right now.
Original Prusa Mini + Smooth PEI
Prusa Slicer 2.6.0
Respondido : 09/01/2020 4:22 pm
Crawlerin
(@crawlerin)
@geoper2
It is possible they release R2 of plastic parts. I redid zipties at least, those were super tightebed and in left-most position on X carriage was pulled back by cables. I was worried about too much strain. These mods allow even more slack.
Respondido : 09/01/2020 7:51 pm
NotJannet
(@notjannet)
For anyone who's not seen it already, they've already updated the designs for securing the minda cable on Mini's yet to be shipped out.
They showed this in a blog post -> https://blog.prusaprinters.org/2019-recap-plans-for-2020-and-original-prusa-mini-update/
Respondido : 23/01/2020 10:52 pm
Tracy
(@tracy)
Posted by: @notjannet
This update didn't fix the issue. My Mini arrived in early February and the minda failed after 3 weeks.
Respondido : 02/03/2020 2:26 pm
Clemens M.
(@clemens-m)
Posted by: @tracy
Could you identify the position of the cable brake in the Minda cable. Is it at the position when cable changes from fixed position to flex position for movement of z- and x- axis? Or was it in another place?
Best regards, Clemens (getting nervous)
Respondido : 02/03/2020 5:21 pm
blsmit5728
(@blsmit5728)
Here is where mine broke, they replaced it quickly.
Respondido : 07/05/2020 4:22 pm
Tgx
 Tgx
(@tgx)
I simply removed only the upper zip tie and it seems to work fine. 😉
Respondido : 08/05/2020 6:43 am
