ESP32 CAM - Prusa Connect - Camera for print progress
jerzeek
(@jerzeek)
Hi All,
Now that Prusa Connect is here, it is time to fully take advantage of the ecosystem and build a camera monitoring system for you.
I'm planning to start a Kickstarter/crowd supply project for a plug-and-play solution to have a camera for your Prusa Mini or Prusa MK4
This project for me started in 2021 when I already made my first boards ( https://hackaday.io/project/182811-esp32-cam-prusa-mini), this worked great for me, but was difficult to setup, now with prusa connect it is time to share it more broadly, and make it easy for you to integrate.
This post marks the start of an adventure, the goal is to gather ideas and feedback from you, and the community. So that when we launch a campaign it is a product you would actually like to use!
Please let me know if you like this project,  and if you have suggestions
Later I will follow up with more details
Napsal : 15/11/2023 10:30 am
2 lidem se líbí
jeffreyrr
(@jeffreyrr)
RE: ESP32 CAM - Prusa Connect - Camera for print progress
This looks awesome, would love more details on this!
Napsal : 13/12/2023 3:40 pm
Renze
(@renze)
I also would like to know more. Your 2021 board was clever positioned behind the mini+ lcd. Makes me wonder how you are planning on doing this for the MK4. Keep on the good work 💪
Napsal : 14/12/2023 11:24 pm
jerzeek
(@jerzeek)
Made it into this:
https://jerrydevos.nl/print-camera-kickstart/
Napsal : 18/12/2023 2:32 pm
jerzeek
(@jerzeek)
I managed to set up a little webshop! So now it is super easy to get one 😎
You can visit the webshop here:  https://jerrydevos.nl/product/printcam-prusa-mini-print-progress-camera/
Napsal : 29/01/2024 7:49 am
dmz
 dmz
(@dmz)
Page Not Found
The page you are looking for does not exist, or it has been moved. Please try searching using the form below.
Any chance you can share the STL for the esp32cam X axis case? I've got several esp32 cam sitting around and just need to get a usb power/passthrough cable.
I'll give this one a try in the mean time https://www.printables.com/model/437324-esp32-cam-mount-for-prusa-mini-x-axis-stepper-moto
This post was modified před 2 years by dmz
Napsal : 30/04/2024 1:46 pm
