Spare parts strategy?
Thierry09
(@thierry09)
Got a brand new MK4 a few weeks ago. It makes the job. Î’m really happy with it.
Then I have to think about close future. Changing parts that will need to.
As the nextruder adpator is not available what shoul I do? Wait? Buy a new one piece nozzle for 30€?
Then for whom has a good feed back with these machines is there any other spare part to recommand having on the shelf at home?
thank you!
 Thierry
Best Answer by vhubbard:
For me a sock was first.   Then a thermister.  From my experience thermisters tend to go out the most.  Then a heater element, alternate nozzle sizes as desired.  I also have a spare aluminum hot end.   At that point more spare parts for a hobby machine doesn't seem worth it for me.
I decided to use the new 1 piece nozzles.  Why?  No hot torquing needed.   With the v6 adapter you still must re-torque the nozzle when hot according to the instructions.  I think this is to assure no leaking.   Working on a hot hotend is something I want to avoid from now on.   The one piece nozzle is tightend at room temp.
Napsal : 18/09/2023 3:32 pm
vhubbard
(@vhubbard)
Napsal : 21/09/2023 4:06 am
Thierry09
(@thierry09)
RE: Spare parts strategy?
Thank you for your suggestions. I’ve bought:
Prusa Nozzle brass - 0.6 mm
1 pcs
29,90 €
Nextruder V6 Nozzle Adapter - available!
1 pcs
28,99 €
Prusa Nozzle brass - 0.4 mm
1 pcs
29,90 €
Thermistor NTC 100k - 90 mm
1 pcs
12,59 €
Nextruder heaterblock
1 pcs
14,69 €
MK4 Heater 40 W - 120 mm
1 pcs
12,59 €
Heatbed thermistor set
1 pcs
7,19 €
I will see then if it’s enough for a while.
Regards
Napsal : 23/09/2023 4:53 am
