ESP32 Cam Support
Stránka 4 / 4
Unicorn3D
(@unicorn3d)
RE: ESP32 Cam Support
Now I am curious: The XL has a USB-C outlet which does not provide any power.
Did anyone figure out if there is a way to get power from the XL for a puny consumer like a camera?
[If I remember my power consumption measurements correctly than using PLA 5 color printing was way below what the three power supplies should be able to output. (granted - my power measurement tools might not account for power spikes).]
Napsal : 07/04/2024 8:20 pm
ManelTo
(@manelto)
No, no, it is not a converter "with" a USB port. It is a converter and a USB port. You need to solder the wires coming out of the DCDC converter to the USB port board. I bought a quality DCDC converter. I didn't want to use a cheap Chinese one that could give me problems with the printer. I also had to remix the cover, to accommodate the converter and port. You also have to solder some pins on the 12v-32v connection to put it on the MK4 connections.
Later I will post the design as well as the instructions.
Posted by: @rainer-2
Good idea, didn't know there was a converter with USB.
Sorry for my poor English. I try to do my best.
Napsal : 08/04/2024 6:39 am
ManelTo
(@manelto)
The MK4 also has a USB-C port, but it also lacks power. That's why I had to make my design to add one.
Napsal : 08/04/2024 6:40 am
Pandhabeer
(@pandhabeer)
Getting stuck at inserting ISRG Root X1 Code
So I managed to pull the root from Prusa webcam website ( https://webcam.connect.prusa3d.com/) with the use of the tutorial, but I am confused what I am supposed to do with the root code. The tutorial says: "Now we can open the certificate in a text editor and save it in the source code". Which source code? The example source code for the ESP32 Cam? When I insert this code directly into the esp32 cam example code with my right SSID + password and click compile I get the following error:
Where am I supposed to compile the root code? What is meant with the source code? I could not find the answers online unfortunately.
Thanks in advance.
Napsal : 14/04/2024 9:06 pm
ManelTo
(@manelto)
https://www.printables.com/es/model/855702-usb-charging-connection-for-mk4-conexion-carga-usb
Napsal : 24/04/2024 3:17 pm
johnyHV
(@johnyhv)
Wow, this looks perfect ManelTo
This post was modified před 2 years by johnyHV
Napsal : 24/04/2024 3:21 pm
johnyHV
(@johnyhv)
Hello guys. Here is new oficial SW for the camera
https://github.com/prusa3d/Prusa-Firmware-ESP32-Cam
https://blog.prusa3d.com/development-of-the-open-source-camera-firmware-solution-from-the-community-for-prusa-printers_94421/
Napsal : 24/04/2024 3:22 pm
1 lidem se líbí
Rainer
(@rainer-2)
Of course I installed your version straight away.  Unfortunately, it's not working properly yet.
It's extremely laggy for me and the camera doesn't seem to work either.  Prusa Connect connection is not working yet. I will try again tomorrow.
Otherwise I will fall back on your old version.  It usually worked perfectly.
Does anyone know if there are differences in the quality of the modules? Sources for good devices? Perhaps also with an antenna and with the resistor already re-soldered.
Napsal : 24/04/2024 7:07 pm
MarkusRe
(@markusre)
On AliExpress ESP32 Cam kits with a FOV 160° camera always have 8 MB PSRAM. Can anybody confirm a 8MB board is no problem?
Napsal : 24/04/2024 9:02 pm
Pandhabeer
(@pandhabeer)
Solved it!
Posted by: @pandhabeer
Thanks in advance.
Napsal : 25/04/2024 1:33 pm
johnyHV
(@johnyhv)
I tested only 4MB PSRAM, but 8MB PSRAM is probably fine too
Posted by: @markusre
Napsal : 25/04/2024 4:17 pm
1 lidem se líbí
MarkusRe
(@markusre)
My camera was sold with 8MB PSRAM, have not check it is really 8MB, but can confirm installation worked without any problems.
Posted by: @johnyhv
Napsal : 03/05/2024 9:25 pm
idiogenic
(@idiogenic)
Is anyone using the Freenove Wrover camera? I bought one without noticing that support for this cam is still pending and I'm not smart enough to figure this out with a good guide.
Napsal : 26/11/2024 4:10 am
idiogenic
(@idiogenic)
Ok, managed to get the software installed and I can log in to the camera from my local network but I can't get any images. Refresh image
Refresh snapshot/download image etc - none of them work.
Any tips?
Napsal : 26/11/2024 5:04 am
stevo1957
(@stevo1957)
Delay in transferring snapshot to Prusa Connect when ESP32 is turned on
I have just setup an ESP32-cam.
When I turn it on, there is no camera feed image and a considerable delay of 5 or 10 minutes for the first snapshot to display in Prusa Connect. After the delay, images will change every 30 seconds as per configuration.
Any ideas as to what is happening here?
Napsal : 31/01/2025 8:47 am
Paul
 Paul
(@paul-21)
My esp32 cam behaves similarly. Using its own app I get picture updates within a few seconds but it can take a few minutes to get through the prusa server and back after switch on.
Regards,
Paul
Napsal : 31/01/2025 9:52 am
1 lidem se líbí
Jean
 Jean
(@jean-3)
Prusa Connect, ESP32  camera_50.129.156 (ESP32-CAM with OV2640)
ESP32:  Firmware Version 1.1.2, Build Jan 2 2025 19:03:12
Great review and innovation to adapt this Cam (Kudo).
Now with this great machine (MK4S) of mine and low knowledge on most of the adhoc process; my question is as follow:
Do I have the correct build for this type of Cam?  This Cam with Prusa Connect, is working and connecting however, seemed very unreliable in getting the snap shot, and should I use an antenna, I find the connection slow at time?  I'm sure there are many ways to solve this, but I'm low on knowledge and resources.
Any comments\suggestions
Thanks
Napsal : 02/03/2025 3:20 pm
Stránka 4 / 4
